Locating VW Engine Code on Vehicle: Step-by-Step Guide to Identify Original Engine
passat ajm 172438 7
  • #1 2675419
    passat ajm
    I apologize for such a laconic question, but maybe there will be someone so polite and write where on the VW engine to find its code. Browsing through the posts and searching in many places, unfortunately, I did not find any information on this topic. I know that you can read this information on the plate next to the spare wheel, but when you are not sure that the engine is original, then ... where to look?
    Thank you in advance and best regards to all forum members.
  • #2 2676759
    krzysztof1291
    Help: 31
    Rate: 151
    Read the engine number, the first 3 characters are the engine code.
  • #3 2677450
    starter55
    Help: 31
    Rate: 103
    I agree with the previous speaker
    I will add this page because I used to have a big problem with it, so I will be happy to help
    http://vwgolf.pl/silniki_VW.html
    Good luck.
  • #4 2678611
    passat ajm
    Welcome back.
    I don't mean to know what engine in my car should be, because I know it (AJM). I read it from the board. But I am asking for tips if, and if so, where can I find such information on the engine block. I am not the first owner of the car, so I cannot be sure that the factory engine has not been replaced, maybe even with a different type. Certainty about the type of engine is necessary for me to correctly identify the necessary equipment parts (flow, turbine, etc.), which started to fall apart.
    Thanks also for the table with the technical data, although I wasn't looking for it and there is no data on AJM engines.
    Best wishes.
    I am counting on a specific hint - if there is one.
    starter55
    Help: 31
    Rate: 103
    You will have the number at the level of the 3rd cylinder - on the block, of course,
    the number should also be on the sticker on the timing cover.
    in the attached file you have
    Engine AJM with Pump Injection System: Design and Function (eng.)
    • ajm_eng.pdf (1.38 MB) You must be logged in to download this attachment.
  • #6 3531098
    Huzar76
    The number should be on a sticker on the timing cover.
  • #7 3531261
    starter55
    Help: 31
    Rate: 103
    buddy @ huzar76 I think my friend passat ajm from May 2006 coped with this number pay attention to the date of posts
    Besides, I have already mentioned this place in the previous post
    However, welcome to the forum and best regards.
  • #8 8846593
    ANDRZEJ67
    Rate: 54
    I am asking for help in determining the engine code that will fit the Golf IV 1.4 16v AXP code. I mean what engines without accessories will fit (engine codes). The original AXP is obliterated and there is no engine with this code in the area.
To locate the VW engine code, users are advised to check the engine block, specifically at the level of the third cylinder. The engine code can also be found on a sticker located on the timing cover. For those uncertain about the originality of their engine, it is important to verify the code against the vehicle's documentation, as the engine may have been replaced. Additional resources, such as a dedicated webpage for VW engines, can provide further assistance. The discussion also touches on the need for accurate engine identification to source compatible parts.
