Ford Focus MK2 1.8 TDCI 2008: Interior Heating Issues, Thermostat & Heater Pipe Check, Solutions
greglow 10998 2
  • Both hot heater hoses: clogged heater core or restricted flow?
    #1 16196478
    greglow
    Rate: 41
    The frosts and dubious pleasure of driving in a cold car have passed, but not quite. Now, when it is outside about 0 ° C I noticed that the maximum heating from the vents is at most summer air. What I was able to determine:
    - T sensor temperature after heating is 90oC (checked in Forscan)
    - you can see that the thermostat does not open too soon (cold radiator hose) on short routes, hot after a long time
    - the fluid in the expansion tank is quite warm
    - clean fluid, adequate level
    - soft hoses, no bubbles in the expansion tank
    - the most important: BOTH heater pipes inside the cabin (next to the passenger's legs) are hot (but I don't know if the hot one doesn't heat the other one because they are very close together)
    Does this mean that the heater is clogged? I can't clean the system in the near future and I have a long way to go (650km). Can I safely apply any specific drug added to the fluid on an ad hoc basis to unlock the system and return the fluid normally when I return?
  • #2 16196538
    coperfild
    Help: 291
    Rate: 1697
    Flap warmly cold?
  • #3 16199321
    greglow
    Rate: 41
    As they often say: the darkest under the lantern ... This morning I took out the radio and it turned out that instead of slipping in and out in the armor, it bent and straightened, which of course did not cause any movement of the flip ... The other thing is why the rope buckled - that's not I know, but after properly bending the link it seems to work again. Subject to close
