Ford Focus MK1 - Troubleshooting Non-Functioning Blower Across All Gears
Zwirson11 28299 8
  • #1 16976046
    Zwirson11
    Rate: 12
    As in the topic from yesterday I do not work blower on any gear, according to it can not be heard. The car is a Ford Focus MK1 where to start to eliminate this problem?
  • #2 16976063
    piotrekwoj1
    Help: 947
    Rate: 3433
    From checking the fuses.
  • #3 16976587
    Ireneo
    Help: 747
    Rate: 2470
    Or a fan.
  • #4 16976645
    migmig85
    Help: 85
    Rate: 337
    Ireneo wrote:
    Or a fan.
    Briefly.
  • #5 16976817
    sebaoo2
    Help: 16
    Rate: 156
    In the engine compartment, fuse F64.
    Pawel wawa
    Help: 1262
    Rate: 4432
    If you look at it correctly, you have F64 and F65 check it, you even have it described on the sticker. These are "mini" fuses.
  • #7 16978684
    Zwirson11
    Rate: 12
    Well, when I put these pictures I just watched and I just checked them but it has unfortunately changed, is it possible that this thermal fuse?
  • #8 16978723
    Strumien swiadomosci swia
    Help: 1405
    Rate: 6430
    And it's so difficult to pull out the fan, not easy, but before that I would connect the light bulb and see if there is voltage to the fan.
  • #9 16978768
    karol1977
    Rate: 107
    Just like a colleague Strumien writes> plug in a light bulb> (check if the fan turns - light and without resistance) When the voltage comes up the bulb burns then you have a thermal fuse (and I won't say it happens :D ) or, as a last resort, a fan motor
    If it doesn't, check the voltage on the speed controller (does it come in and out) :D
    If you have checked the fuses (they are ok), the regulator should be energized
    If there is no damaged beam, then analogically after the switch :D
    Powodzonka :spoko:
The discussion revolves around troubleshooting a non-functioning blower in a Ford Focus MK1. Initial suggestions include checking the fuses, specifically F64 and F65, which are mini fuses located in the engine compartment. If the fuses are intact, users recommend testing for voltage at the fan by connecting a light bulb to determine if the thermal fuse is faulty or if the fan motor itself is defective. Additionally, checking the speed controller for voltage is advised if the fuses are operational. The complexity of accessing the fan is noted, but it is emphasized that verifying the electrical connections is crucial for diagnosing the issue.
