Microprocessor Rectifiers: Automatic Current Selection in Yato 8301 (8A) for 60Ah Battery?
basso 5211 9
Will a Yato 8301 microprocessor charger automatically choose the charging current for a 60Ah battery, or will it simply charge at the selected 8A setting and potentially damage the battery?
The 8A setting is effectively the charger’s available/selected maximum current, not an intelligent current choice based on battery capacity, and the actual charging current will fall on its own as the battery voltage rises [#16206409][#16207443] If the charger limits voltage to about 14.8V, the battery should not gas, and the current can be high at the start and then drop from tens of amps to a few amps or even below 1A as charging continues [#16205822][#16206409] The old “charge at 10% of capacity” rule is treated here as outdated; the key point is proper voltage limitation, not a fixed current tied to Ah [#16205822][#16206409] For a 60Ah battery, the discussion suggests using a charger with a good voltage limiter and, in practice, limiting the initial current to around 6A is reasonable, though the battery will not keep drawing that much for long [#16206409] The cheap Yato-style chargers are also described as more of a marketing table than precise battery matching, and some may overheat or reduce current after a short time [#16207443][#16209852]
  • #1 16205794
    basso
    Hi.
    I am not an expert.
    Miracles of invisibility are written in the instructions, but what is it really like?
    The question is: with a microprocessor rectifier, eg Yato 8301 (8A), when charging a 60Ah battery, will it charge with a maximum current of 8A or will it choose the current depending on the voltage / capacity etc?
    Most of the user manuals have tables.
    For example, in Yato 8301:
    8 A for battery capacity. 20 - 200 Ah
    2 A for battery capacity. 5 - 40 Ah
    I have a 60Ah battery, so looking at the table I have to choose the FAST (8A) option, the question is whether choosing 8A will not damage it, because it is more than 10% of the capacity ... Or maybe it is set to 8A, and he somehow selects it during charging (increases, decreases) => well finally there is a microprocessor, so I do not see a problem to give the perfect current depending on the capacity.
    Thanks in advance.
  • #2 16205822
  • #3 16205838
    leonov
    Help: 1039
    Rate: 2247
    Regarding this rectifier Link :D
  • #4 16206061
    basso
    I do not fully understand ... Maybe otherwise, I understand, it is so that in theory the batteries have protection and you can give them up to 200A at the input, and in practice they do not fully work and can be damaged?
    I also mean: YATO YT-8302, Maximum charging current: 12 A. It can also be charged with 6A current ,,,
  • #5 16206409
  • #6 16206473
    basso
    @eurotips
    Thanks for your comprehensive answer.
    But why manufacturers of rectifiers, without fear in the tables, do not hesitate to charge with such currents?
    For example Yato Y8303 (15A)
    Proposed current for a 50Ah battery => 10A - 12A or 15A range :|
    Well, I can not see any part of the 10% capacity standard known to us here; /
  • #7 16207443
  • #8 16209214
    basso
    Thanks.
    Noiii I'm not such a disfigurement to myself ...
    So, to sum up: Buy a rectifier so that the charging current is close to 10% of the capacity. Let's even say 12-15% ... because the charging current is lower or "in a moment" will be lower.
  • #9 16209852
  • #10 16209955
    basso
    aaa ... ok
    Thanks.
    I will buy it soon, because there is also such a miracle in Biedronka on promotion :)
The discussion revolves around the Yato 8301 microprocessor rectifier and its suitability for charging a 60Ah battery. Users express concerns about whether the rectifier will charge at its maximum rated current of 8A or adjust the current based on the battery's voltage and capacity. Some participants argue that modern batteries can handle higher initial charging currents without damage, as long as the voltage is controlled. The conversation highlights the importance of selecting a charging current close to 10-15% of the battery's capacity for optimal performance. Users also discuss the limitations of lower-cost rectifiers, which may overheat or require frequent shutdowns, and suggest considering more reliable options for continuous operation.
