Comparing Verto, Bass Poland, Einhell, and Ferm Routers: Which Is Most Reliable?
comandos21 8859 7
  • #1 16217457
    comandos21
    Rate: 105
    Hello, I have a dilemma ...
    I need a router that is not unreliable and has good service.
    The companies that overlap me at a glance are:
    Verto
    Bass Poland
    Einhell
    Ferm
    The MAX he wants to spend is PLN 250
    He would use a milling machine once or several times a year to mill grooves 1cm / 1cm
    Only Verto (media expert) and Ferm (Rolzbyt) are available on site in the city
    Links here:
    in brackets info for how much you can buy
    Verto (media expert PLN 185) adds 5 cutters to the set
    [url=]http://www.ceneo.pl/24958754;pla#tab=spec[/url]
    Bass Poland (PLN 200 allegro)
    [url=]http://www.narzedzia24.info/frezarka-gornowrzecionowa-1500w.html[/url]
    Ferm (Rolzbyt stationary store PLN 250) 2 cutters included
    [url=]http://www.ferm-polska.pl/oferta-ferm/frezarka-gornowrzecionowa-1200w-ferm-regular-prm1018/[/url]
    Einhell Home (Allegro PLN 195)
    [url=]http://www.ceneo.pl/25573553;pla#tab=spec[/url]
    I would like to add that I have a lot of Verto tools and they have been working for 9 years without fail but 9 years ago the technologies probably had more solid hence my thinking about companies
    I am asking for help in choosing ;)
  • #2 16217594
    jacur
    Level 32  
    Help: 166
    Rate: 295
    I have Einhela worked 20 minutes and began to howl the spindle bearing after replacement for high speed working properly.
  • #3 16217798
    comandos21
    Rate: 105
    This einhell is falling out
  • #4 16219942
    comandos21
    Rate: 105
    Nobody else will say ???
  • #5 16220613
    vorlog
    Level 40  
    Help: 527
    Rate: 2586
    I recently bought a Skil 1840 milling machine, slightly more expensive, for 335 PLN, I like this brand.
    This is not a professional equipment, I need it for renovation and hobby purposes.
    It works nice, only (like probably most in this class) has not a special lead on the posts - it likes very even pressure, it wedges itself differently. One of the advantages - a metal outlet for a vacuum cleaner, not a plastic tip.
    After a long study of the subject in such money, there is no point in counting on a competitive tool.
    Maybe Einhel, but RT-RO 55, because this model Home (TH-RO) is a toy - I had it in my store.
    Regards, V.
  • #6 16246658
    comandos21
    Rate: 105
    Ok thanks for the feedback. I will, however, try Verto, I have this company's tools and they are after 6 years.
  • #7 17072014
    comandos21
    Rate: 105
    The Verto milling machine works great so far. I bought for 185 PLN at MediaExpert.
  • Check service and spare parts availability
    #8 17072035
    zworys
    Help: 519
    Rate: 573
    Buddy in this price range do not count on a miracle. DIY tools are available. Personally, I have Verto - it works correctly, but I still have some similar tools and unfortunately there is no rule - sometimes Einhell works long and good, and another tool of this company falls immediately after purchase. Unfortunately, all of them are really "Chinese" only signed by individual companies. Rather, in your place I would check the service and availability of spare parts because then there is a chance that the tool will work a little and not be thrown after the first failure.
The discussion revolves around the reliability of routers from four brands: Verto, Bass Poland, Einhell, and Ferm, with a budget limit of PLN 250. Users share experiences, noting that Einhell routers may have quality issues, with one user reporting a spindle bearing failure after minimal use. Verto routers receive positive feedback for their durability, with one user stating satisfaction after six years of use. Concerns are raised about the overall quality of DIY tools in this price range, with suggestions to prioritize service and availability of spare parts. The consensus leans towards Verto as a reliable option, while caution is advised regarding Einhell's consistency.
