- CMD Command Line: Delete All Files and Folders without Deleting Original Folder (del & RD)
badboy23 34821 8
  • #1 16237938
    badboy23
    Rate: 49
    Hello, I need from the command line, delete all files and folders from the folder, leaving the folder untouched.
    I tried del and RD but it does not go too far.
  • #2 16237953
    Kasek21
    Help: 4981
    Rate: 3547
    enter: del *. *
  • #3 16238016
    badboy23
    Rate: 49
    Kasek21 wrote:
    enter: del *. *
    I need to be in this directory?
    I also did: \ test *. * Although I was not physically in the directory.
  • #5 16238029
    Kolobos
    IT specialist
    Help: 17171
    Rate: 10456
    No, but you have to enter the correct commands ...
    Np: del e: \ test \ *. *
    Ps. Description of dos dos commands is generally available, maybe it is worth reading and understanding?
  • #6 16238368
    badboy23
    Rate: 49
    That's basically a bad word, and I did not even write the post correctly. I've already corrected, instead of a directory I should use the folder expression. Excuse me.
  • #7 16238379
    dt1
    Admin of Computers group
    Help: 7315
    Rate: 8292
    Properly:
    rd /s e:\test
    This approach will delete all contents of the e: \ test (including subfolders) and the folder itself. Then you can create it again - will not this solution be better than deleting everything separately? Del will delete files, so each subfolder seems to have to be replaced with a name to be deleted.
  • #8 16238381
    yogi009
    Help: 848
    Rate: 2655
    In the past, the deltree command functioned , I do not know if it is still valid.
  • Using rd /s and md to recreate the directory
    #9 16238392
    badboy23
    Rate: 49
    dt1 wrote:
    Properly:
    rd /s e:\test
    I think you're right to use rd & md and after the case
    Deltree give it away from xp but I can be wrong.
The discussion revolves around using CMD command line to delete all files and folders within a specified directory while keeping the directory itself intact. Users suggest using the command "del *.*" to delete files, but clarify that the command must be executed within the target directory. Another user recommends using "rd /s e:test" to remove all contents, including subfolders, but this command also deletes the folder itself. The conversation touches on the historical "deltree" command, which is no longer available in modern systems, and suggests using "rd" followed by "md" to recreate the folder after deletion.
