CMD Command: Copy Files from CD to Specific Path on Hard Drive (Example Included)
kotar92 120183 6
  • #1 5832346
    kotar92
    Rate: 15
    Hello. I would like to know if there is a command in CMD that starts copying certain files (e.g. from CD) to a specific path on the hard drive. If this is the case, please give an example.
  • #2 5832380
  • #3 5832441
    kotar92
    Rate: 15
    Give a specific command if I want to copy the file from D: \ xxx \ xxx.exe to the folder C: \ yyy \
    Kolobos
    IT specialist
    Help: 17171
    Rate: 10456
    copy D:\xxx\xxx.exe C:\yyy\
  • #6 5832470
    kotar92
    Rate: 15
    Thanks for the help
  • #7 5832473
The discussion revolves around using CMD commands to copy files from a CD to a specific path on a hard drive. Users inquire about the appropriate commands, with examples provided for both single file and multiple file copying. The command `copy D:xxxxxx.exe C:yyy` is suggested for copying a specific executable file, while `xcopy D:*.exe C:yyy` is recommended for extracting all executable files from the CD to the designated folder.
