Intrusive Charging Assistant on KitKat 4.4.4 Android Phone: Unidentified App Update Issue
Krzys55 3108 16
How can I identify and remove an intrusive charging assistant that keeps reappearing on my Android 4.4.4 phone after charging or rebooting?
It is probably coming from a system-acceleration, cleaner, or launcher-type app rather than a standalone feature, so the first step is to check any apps that speed up Android, clean background processes, or replace the launcher [#16247213] If you cannot identify it directly, one suggested method is to remove app updates one by one and see when the charging assistant disappears, using a list of common culprits as a guide [#16247349] One reply also noted that a similar charging/lock-screen option appeared inside a weather applet, so the source may be an app with bundled extras rather than an obvious “cleaner” app [#16249233] AdGuard was suspected by one user, but the original poster said the charging assistant was not coming from AdGuard [#16249478][#16253899]
  • #1 16247065
    Krzys55
    Help: 89
    Rate: 303
    Hello all . An intrusive charging assistant appeared on my kitkat 4.4.4 android phone. I was given it by one of the applications after the update. It reappears after switching off. I read that it can be Clean Master or CM security but I don't have these applications. Do any of your colleagues know which application is so generous?
  • #2 16247078
    bubu1769
    Help: 1177
    Rate: 2372
    Give a screenshot of this assistant, because nobody will tell you what exactly it is. Such add-ons usually have system acceleration programs.
  • #3 16247196
    Krzys55
    Help: 89
    Rate: 303
    Here it is a bit difficult to see but I have nothing to do better. Intrusive Charging Assistant on KitKat 4.4.4 Android Phone: Unidentified App Update Issue Intrusive Charging Assistant on KitKat 4.4.4 Android Phone: Unidentified App Update Issue Intrusive Charging Assistant on KitKat 4.4.4 Android Phone: Unidentified App Update Issue
  • #4 16247213
    bubu1769
    Help: 1177
    Rate: 2372
    In fact very similar to the Clean Master functions. Have you installed any application to speed up the android, clean background applications or some launcher?
    http://blog.apusapps.com/apus-launcher-v2/
  • #5 16247266
    Krzys55
    Help: 89
    Rate: 303
    I did not install the afterburner. I have a Super User, but updates have been blocked for over a year. ES explorator has another assistant and is turned off. Launcher is not installed. I have done root but it's been over a year and it wasn't before.
  • #6 16247290
    bubu1769
    Help: 1177
    Rate: 2372
    and what other applications do you have installed?
  • #7 16247328
    Krzys55
    Help: 89
    Rate: 303
    I did not install any new ones before the appearance of this gift. I also have a busybox but also for a long time and there is nothing there. How to track it and remove it? In the settings it has only one "disabled" function but on the second day after connecting the charger it is back.
  • #9 16247414
    Krzys55
    Help: 89
    Rate: 303
    Too much work removing and reinstalling. If it's one of the system applications, the whole work would be wasted anyway. There is no other way ? Such forced gifts are annoying.
  • #10 16247583
    bubu1769
    Help: 1177
    Rate: 2372
    It's hard to say anything since you don't know what applications you have installed and the booster screen itself looks like many other similar ones.
  • #11 16248121
    Krzys55
    Help: 89
    Rate: 303
    Apart from the previously mentioned ones, I only have a lucky patcher, auto map, adguard, flashlight, Adobe, work schedule. The rest removed
  • #12 16249233
    bubu1769
    Help: 1177
    Rate: 2372
    Out of curiosity, I installed adguard + yandex browser, and a moment ago I had an oplet with a weather forecast and in the upper right year there was a charging lock screen option. Unfortunately, I did not have time to investigate it deeper because the application closed. I do not know if it is related to each other, but I will pay attention to it.
  • #13 16249397
    Krzys55
    Help: 89
    Rate: 303
    Ok thanks for the info.
  • #14 16249478
    xSzwagier
    Help: 35
    Rate: 72
    adguard adds crap; get yourself adawaya and add filters from the authors site - he's system-wide.
  • #15 16249793
    Krzys55
    Help: 89
    Rate: 303
    I tested ADAWAY some time ago, ADGUARD fares better and this charging assistant does not come from it.
  • #16 16252374
    bubu1769
    Help: 1177
    Rate: 2372
    I had this weather applet again and again I couldn't see more of it, interestingly it looks like it doesn't show up until late at night. The only thing I can suggest now is go to the application settings and clear the data from adgard.
  • #17 16253899
    Krzys55
    Help: 89
    Rate: 303
    As I mentioned before I have ADGUARD for a long time and this assistant is not from him.
An intrusive charging assistant has appeared on a KitKat 4.4.4 Android phone, reportedly following an app update. The user suspects it may be linked to system acceleration programs, similar to Clean Master, but does not have that app installed. Various responses suggest checking installed applications, as the assistant resembles features from optimization tools. The user has a limited set of applications, including Lucky Patcher, AdGuard, and others, but has ruled out recent installations as the cause. Suggestions include removing updates from apps one by one to identify the culprit, although the user expresses frustration at the potential effort involved. The discussion also touches on the possibility of the assistant being related to other apps like weather widgets or ad blockers.
