JVC LT-32V450 - It only succeeded once to connect to the WiFi router
RolnikZDR 18237 6
  • #1 16259773
    RolnikZDR
    Rate: 11
    The problem is like in the subject. From the above The television model mentioned above has only been able to connect TV and WiFi once. Detected WiFi automatically after entering the network settings on the TV. Everything worked just fine. After turning off the TV and turning it back on, you can not connect to the internet, it does not detect WiFi networks. As for me, this is a very strange case. Any ideas ?
  • #2 16259852
    sosarek
    Help: 9320
    Rate: 15532
    What did you do - did you restore the default network settings on tv? Which device are you trying to connect with?
    Z
    Pka, Poznań, 60-850
  • #3 16260072
    RolnikZDR
    Rate: 11
    In the "network / Internet settings" option there is no possibility of default settings. Is only:
    1. Network type
    2. Press the WPS button on the Router
    3. Internet speed test
    4. Advanced settings (including automatic and manual IP and DNS configuration)
    The Router model is the IDU - 200 Wi-Fi Router
    I would like to remind you that this is very strange because it worked normally the first time and after not switching it on again.
    I will add that not in any mode you can enter the network settings because eg in the mode (In the list of sources eg HDMI 1, HDMI 2, TV, HDSTB etc.) TV network settings work but in "Wireless Display" after turning on the network settings "Menu Is Not Available" message appears
  • #4 16260543
    Vytautas_YT
    Level 30  
    Help: 128
    Rate: 297
    And in Wireless Display TV it does not accidentally switch to transmit mode? Try to restore the TV to factory settings and then connect.
  • #5 16260606
    RolnikZDR
    Rate: 11
    Unfortunately, I've tried it and it does not help. The TV is new for warranty so I will take it to the store and let them tire. I would not like to just go out on a fool, I can not connect to WiFi, the more I have connected myself normally ...
  • #7 16260721
    RolnikZDR
    Rate: 11
    This is what I tried, the laptop can see the normally shared network via WiFi with the tel. While the TV does not.
The JVC LT-32V450 television successfully connected to a WiFi network only once, after which it failed to detect any networks upon reboot. The user noted that the network settings menu is limited, lacking an option to restore default settings. Suggestions from other users included checking if the TV was in transmit mode, restoring factory settings, and attempting to connect to a mobile hotspot, but these did not resolve the issue. The user plans to return the TV for warranty service due to the persistent connectivity problem.
