Samsung Galaxy S5: Half Display Green Spot Issue - Causes & Repair Fees
GolonTheGalera 5517 8
  • #1 16286256
    GolonTheGalera
    Hello, a green spot appeared on my phone - half the display. What is the reason for this stain, and how much would the repair fee be?
    • Samsung Galaxy S5: Half Display Green Spot Issue - Causes & Repair Fees 20170217_171905.jpg (439.22 KB) You must be logged in to download this attachment.
  • #2 16286321
    lukasrsv
    Help: 41
    Rate: 165
    It looks like a broken display. Haven't you pressed the phone too hard sometimes?
  • #3 16286329
    GolonTheGalera
    I don't know because I bought the phone recently.
  • #4 16286336
    lukasrsv
    Help: 41
    Rate: 165
    Is there a stain on every background?
  • #5 16286342
    GolonTheGalera
    Yes on any background.
  • #6 16286356
    KamGr
    Help: 77
    Rate: 203
    After removing, it looks like your display is damaged and can be replaced. The display itself costs over PLN 600 + the service will charge you for the job.
  • #7 16286914
    AxelNext
    Help: 265
    Rate: 454
    KamGr wrote:
    the display costs over PLN 600 + the service will charge you for the job.
    That is, an unprofitable repair since a nice drug under warranty can be bought for about PLN 650.
  • #8 16287410
    pawel9502
    You can also find a little cheaper, for about 300-350 PLN, but in my opinion the weak business + the quality of such a display can be much worse than the original.
  • #9 16288088
    lukasrsv
    Help: 41
    Rate: 165
    Or look for a drug in poor condition, but with the entire display and have some parts for a change. greetings
The discussion revolves around a Samsung Galaxy S5 experiencing a green spot on half of its display. Users suggest that the issue may stem from a damaged display, possibly due to pressure applied to the screen. The display replacement costs are estimated to be over PLN 600, with some suggesting that it may not be cost-effective compared to purchasing a new device, which can be found for around PLN 650. Alternatives include sourcing a cheaper display for PLN 300-350, though concerns about quality are raised. Another suggestion is to find a damaged device for parts.
