Samsung 9005 note 3 green dash on amoled display
paparobert 7122 7
  • #1 16165620
    paparobert
    Rate: 13
    Welcome to the new year.
    The problem concerns the super amoled display, and more precisely the green line along the length of the screen. I must honestly admit that I have seen such defects with flip-flop or sliding phones. What could be the reason? A screen, or some tape connecting the screen to the motherboard?
    Ps please transfer to the appropriate section
  • #2 16166053
    Szymek1989
    Probably a damaged display, the display tape is not movable, which is the case in slide phones. You could, for example, press it in your pocket and that's why the green line was created.
  • #3 16166182
    paparobert
    Rate: 13
    I think so too, but I asked for help because maybe there are some other fault ideas
  • #4 16166326
    KamGr
    Help: 77
    Rate: 203
    As the colleague says above, you have a damaged display, unfortunately.
  • #5 16171124
    paparobert
    Rate: 13
    I understand that with the screen off, there must be no damage. And one more thing. With a dark screen, the line is rarely green, and when the screen is fully lit, it is completely green. This tape does not let me sleep because the symptom is identical. Or maybe a micro contact has been loosened? The screen itself costs 700 PLN in this case and I would rather be sure that it is a damaged screen and not a tape. Sorry I'm so tiring :)
  • #6 16171254
    Szymek1989
    It is not 100% tape, I have already replaced a lot of displays with such symptoms and the reason was always the display, not the tape. Unfortunately, in this model it is expensive due to the glued display to the touch, there are people who stick such things but the cost is not is small.
  • #7 16171549
    tonk
    GSM specialist
    Help: 137
    Rate: 57
    Putting up here won't help
  • #8 16214488
    paparobert
    Rate: 13
    Well. You have to prepare 6 hundred dishes
The discussion revolves around a Samsung Galaxy Note 3 experiencing a green line on its Super AMOLED display. Users suggest that the issue is likely due to a damaged display rather than a problem with the tape connecting the screen to the motherboard. The original poster expresses concern about the cost of replacing the screen, which is approximately 700 PLN, and seeks confirmation that the display is indeed the source of the problem. Responses indicate that similar symptoms have consistently been linked to display damage in this model, emphasizing the high cost of repairs due to the glued nature of the display.
