VW Golf 5 1.9 TDI: Error P0726 Engine Speed Input Circuit - RPM Upper Limit Exceeded
Misha1990 15078 4
  • #1 16303903
    Misha1990
    Rate: 11
    I have a problem with a great car like VW Golf 5. It has stopped working, it turns and does not smoke. Computer shows error P0726 (engine speed input circuit - RPM upper limit exceeded). I don't know what that means exactly and I can't find it anywhere on the net.
    In one topic (https://www.elektroda.pl/rtvforum/topic2589564.html),
    I read that it helps to replace a driver, but I have no idea which one?
    The car does not start, but when it succeeds, it goes out after a while.
    If there is someone who can suggest what to do, I would be grateful.
    Sorry if the topic keeps repeating, I'm new to the forum, but I really haven't found anything to help me.
    marfur30
    Help: 138
    Rate: 386
    It looks like a damaged engine speed sensor on the crankshaft or the harness from the controller to the sensor.
  • #3 16304014
    Misha1990
    Rate: 11
    and I forgot yet. When it starts, it does not react to the gas and goes out when you try to put the gear into gear. Does it have anything to do?
  • #4 16304563
    domex32
    Help: 585
    Rate: 2451
    Give the car to the garage, lack of knowledge and tools, you can't do it, really.
  • #5 16305130
    Misha1990
    Rate: 11
    I replaced. Lata thanked :)
