Opel Astra J (IV), 2013, 1,7 C - Outside temperature sensor error (---)
demolo123 20814 6
  • #1 16311199
    demolo123
    Rate: 8
    Hello, I bought the 2013 Astra Sport Tourer (combi), 1.7 CDTI. I have no indication of the outside temperature in the display, only the lines (---). I replaced the sensor (new) - the same, the voltage on the plug about 5V. Astra is on CAN ... so I don't think much about the display because there are only a few cables (probably 4 or 5). I have no idea what to get ... Someone will advise ....? ..... Maybe someone has a scheme, you can also be insignia (maybe similar ...?)
    Thank you in advance .... Paweł
  • #2 16311556
    piotrekwoj1
    Help: 947
    Rate: 3433
    You need to do diagnostics and view the actual temperature there. If I'm going to be ok then you have to look elsewhere as it will be -40 is a bunch to check. The sensor can be simulated just in case.
  • #3 16311750
    demolo123
    Rate: 8
    Sensor simulate with a resistor ...? .. I have op coma china clone, but nystety astre after lifcie reads - disabled ... :( ... the climate turns on, so I suspect that he sees something there ....
  • #4 16312381
    piotrekwoj1
    Help: 947
    Rate: 3433
    This year the opcom can't cope with something else to be diagnosed. You can only simulate if you have a preview of the actual values.
  • #5 16312601
    demolo123
    Rate: 8
    Checked with another "universal" interface ...- 40 degrees ... where to look for any tips ....
    • Opel Astra J (IV), 2013, 1,7 C - Outside temperature sensor error (---) 20170228_093743.jpg (2.26 MB) You must be logged in to download this attachment.
  • #6 16312645
    piotrekwoj1
    Help: 947
    Rate: 3433
    I wrote the sensor and the beam to check before.
  • #7 16313257
    demolo123
    Rate: 8
    Problem solved ... the malfunction was the wrongly programmed display. I connected Op-Com, and in the tab> Body> Instrument cluster-position OUTSIDE TENPERATURE was not present, - I presented it to present ... it works ...! So thank you all and the topic is closed ...
    • Opel Astra J (IV), 2013, 1,7 C - Outside temperature sensor error (---) 20170228_122153.jpg (3.45 MB) You must be logged in to download this attachment.
The discussion revolves around a 2013 Opel Astra Sport Tourer (1.7 CDTI) experiencing an issue with the outside temperature sensor, which displays only dashes (---) instead of the actual temperature. The user replaced the sensor but continued to face the same problem, suspecting a fault in the display or wiring. Various suggestions were made, including performing diagnostics, simulating the sensor with a resistor, and checking the wiring. Ultimately, the issue was resolved by reprogramming the instrument cluster display using the Op-Com diagnostic tool, which had not previously recognized the outside temperature function.
