Rubbermaid Glue Gun Issues: No Glue Supply Despite Heating, Leakage, Power Parameters 7W and 55W
partyzancik 7554 1
  • #1 16318909
    partyzancik
    Help: 14
    Rate: 176
    Hello. I have a Rubbermaid glue gun.
    Such as this: Rubbermaid Glue Gun Issues: No Glue Supply Despite Heating, Leakage, Power Parameters 7W and 55W )
    The gun was purchased in the Leroy Merlin chain of stores. He performed well most of the time, but later problems arose. He warmed up as usual, but he stopped supplying glue when pressing the stick with a button in the handle, but slowly flowed and dripped as he was placed on this fold-out support. It also happened that molten glue flowed from the side from which the cane was put. I undressed and cleaned, but it did not help. What can cause problems and how to fix it? Can the glue be reused? What do the 2 power parameters on the device housing (7W and 55W) mean?
  • #2 16327486
    tzok
    Help: 3164
    Rate: 6469
    Adhesive feeding is done mechanically, since you have stripped it, you should understand how it works. Probably something has broken. How would you like to "reuse the glue"? The "stick" of the glue must not be pulled back, if you want to give, for example, a different color, you can cut the protruding part of the cane, and push the rest through the gun.
