Allegro Auction Description Vanishes: DNS Change Ineffective Across Browsers
sajki666 3552 12
How can I fix Allegro auction descriptions that appear briefly and then disappear in every desktop browser even after changing DNS?
Reset the affected browsers rather than continuing to change DNS: a portable Chrome version worked, indicating that DNS was functioning correctly [#16332048] [#16332059] Back up bookmarks, uninstall the browser, delete its profile directory, and reinstall it; for Chrome, the profile is under `C:\Users\\AppData\Local\Google\Chrome\User Data\Default` [#16332068] Apply the same uninstall, profile deletion, and reinstall process to Opera [#16332129] The problem was resolved after this procedure [#16332181]
  • #1 16331697
    sajki666
    I have the same problem as my friend:
    https://www.elektroda.pl/rtvforum/topic3309700.html
    I changed the dnsy too and the problem is still there. There is simply no description of the auction on the Allegro, it appears for a second and then disappears. It's the same in every browser.
    FRST in the attachment.
    Thanks for the help in advance.
    • FRST.txt (23.28 KB) You must be logged in to download this attachment.
    • Addition.txt (38.42 KB) You must be logged in to download this attachment.
  • #2 16331934
    Kolobos
    IT specialist
    Help: 17172
    Rate: 10457
    If the problem is the same, why are you writing? In the given thread you have everything specified, change the dnsy to the correct one in the router settings, and block access to the router's panel from the Internet.
  • #3 16331953
    sajki666
    I am writing because changing the dns did not help, but I was counting on the answer what to do with this FRST, do the same as you wrote in this topic (this fix?)?
    And I don't know how to block access to the router from the internet.
  • #4 16331961
    Kolobos
    IT specialist
    Help: 17172
    Rate: 10457
    In this case the fixlist is redundant, there is nothing to remove.
    But changing the dnsow in the router settings is required, replace the screen with the settings (with visible dnsami).
  • #6 16331999
    Kolobos
    IT specialist
    Help: 17172
    Rate: 10457
    Run the cmd window with administrator rights and there:
    ipconfig / flushdns
    Pages should now open correctly.
  • #7 16332026
    sajki666
    Unfortunately, the info is that the DNS resolver cache was successfully flushed, but that doesn't help.
    The auction opens, the description jumps for about 2 seconds and then disappears. It's the same in every browser. On a phone using the same router, it opens normally.
  • #9 16332059
    sajki666
    Everything works fine in this version.
  • #10 16332068
    Kolobos
    IT specialist
    Help: 17172
    Rate: 10457
    Then dnsy is ok.
    Back up Chrome bookmarks, uninstall Chrome, delete profile directory:
    C: \ Users \ sajki \ AppData \ Local \ Google \ Chrome \ User Data \ Default
    Reinstall Chrome and check if it's ok.
  • #11 16332093
    sajki666
    Works on Chrome!
    At the opera, it's still the old way. I want it to work properly also on it, because I use opera.
  • #12 16332129
    Kolobos
    IT specialist
    Help: 17172
    Rate: 10457
    It will do the same. Uninstall, delete profile directory and reinstall.
  • #13 16332181
    sajki666
    It works!!
    thank you very much.
The discussion revolves around a user experiencing issues with auction descriptions disappearing on Allegro after changing DNS settings. Despite attempts to resolve the issue by flushing the DNS cache and using different browsers, the problem persisted. The user found that the auction description displayed briefly before vanishing, while it worked correctly on a mobile device using the same router. Suggestions included using a portable version of Google Chrome, which resolved the issue for that browser. However, the user sought a solution for Opera, leading to recommendations to uninstall and reinstall the browser, including deleting the profile directory, which ultimately resolved the issue.
