Renault CAN-Clip Probe Issue: Diagnostics Fail, Auto VIN Load Error, Clip v146, Chinese Model
majdan1986 11919 14
How can I troubleshoot a Renault CAN-Clip probe that is detected by Clip but cannot automatically read the VIN or communicate with the vehicle after reinstalling the software?
Reinstall Clip on a 32-bit Windows XP system, place it on the C: partition, and reboot, since the replies identify the operating system and installation location as likely causes [#16403758] [#16403998] [#16404371] Confirm that the vehicle ignition is switched on before testing [#16403346] Having four LEDs lit and only one installed driver is not necessarily abnormal; another probe with the same indicators and driver count worked normally [#16406793] If communication still fails after this setup, the thread does not provide a confirmed probe-damage test or definitive hardware repair.
  • CAN-Clip probe detected but vehicle diagnostics fail
    #1 16402492
    majdan1986
    I will not create a new topic, so I will dig up the old one
    I have a question for experts in software and diagnostic hardware.
    Well, I have a Clip (probe), probably Chinese, I bought it 2 years ago on the Allegro for PLN 600, it worked ok, I did not use it for half a year, at that time I reinstalled the system in the computer, and recently I wanted to connect it to the car to check the errors and here it started problems. Well, I installed Clip v146, I connected the probe that was installed as one driver, I fired the Clip (the program sees the probe) on the device all LEDs (4) are on, like everything is ok, but it does not see the car, when you try to automatically load Vin, a message appears that it has failed and please enter it manually, after manual typing and diagnostics, a message appears that the diagnostics failed,
    Does anyone know the problem (maybe I should configure something else) or maybe the probe is damaged
    Help me because I have a little problem in the car and I have to connect somehow
    Moderated By CameR:
    Separated from:
    https://www.elektroda.pl/rtvforum/topic1906950.html
    Reg. 3.1.19. Do not send messages on archival topics if this is another question, especially other than the questioning person. Out of respect for the questioner, create your own topic. You can only add a solution to the problem.
  • #3 16402970
    janusz2008
    Help: 170
    Rate: 515
    It's a pity for the money on this pseudo equipment, I have already won three. And I won't buy it again.
  • #4 16403346
    sebap
    Help: 538
    Rate: 1084
    @ majdan1986 ignition, of course, on?
    @ janusz2008 I have a Clip since 2011, he converted dozens of cars and no problems. As for "pseudo equipment" show another one that Renault will do to such an extent.
  • #5 16403710
    majdan1986
    Yes, the ignition is on, of course, I will add that before reinstalling the system, the problem did not occur, I also checked on another computer (although it is true) also has a new system, and a freshly uploaded clip, but it happens the same.
  • #6 16403758
    ALIBABA I
    Help: 224
    Rate: 538
    Hello, you probably had 32 and now you have 64 and here may be a problem
  • #7 16403998
    sebap
    Help: 538
    Rate: 1084
    As above, 32 or 64bit system? Clip installed on C partition?
  • #8 16404312
    majdan1986
    The system installed is vista 32 bit
  • #9 16404371
    sebap
    Help: 538
    Rate: 1084
    Install XP
  • #10 16406739
    majdan1986
    Hello, I checked with another laptop with windows 7 32 bit, (also newly installed), of course, the clip installed on partition C, the program is ok, it finds the probe and does not want to load the vin or after entering manually communicate with the car, everything was ok with the car connected) the LEDs are lit 4, I am a bit surprised that a lot of people write that when the probe was installed, they needed 4 drivers and for me one, Do you not need to configure the laptop or the CLIP program itself.
    Can it mean a damaged probe (if so, how is it the easiest way to check)
  • #11 16406793
    sebap
    Help: 538
    Rate: 1084
    I have a probe that requires 4 drivers to install, but recently I installed a probe for a friend, and only 1 driver was installed and the LEDs were lit 4 and it worked normally.
  • #12 17331513
    slawarek
    Rate: 212
    Maybe someone had such a problem as in the picture because he does not see the old scenic cars, kango
    soft v172
    • Renault CAN-Clip Probe Issue: Diagnostics Fail, Auto VIN Load Error, Clip v146, Chinese Model kango nie laczy.jpg (172.81 KB) You must be logged in to download this attachment.
  • #13 17331551
    sebap
    Help: 538
    Rate: 1084
    Install Clip again, selected format and reboot the system, necessarily on partition C.
  • Workaround for isodrv.dll error in Clip 212+
    #14 20260533
    puznies0
    If any of you have problems installing Clip in version above 212 and displaying the Dll non trouvée: isodrv.dll error, do not copy any garbage from the AAVIMIsellection.dll patch because it does not do the job, it just corrupts the program and it catches a fatal error ...
    I am writing a solution here because there is a lot of nonsense on the Internet and it is not going to get over it ... The guests themselves, what they trade with it, cannot help ... this is what it looks like to me or Windows 95 in the early stages of development ... By the way, it's strange that no one has updated it so far ...
    The solution to this problem is to install Clip in, for example, version 215 and activate it according to the instructions ... So replacing the Rswin file and so on ... After this procedure, do not copy anything from the patch, but run the installation of version 178 or earlier ... and select update program option ... The installer will of course remove version 215, but some files will be left and replaced with version 178 .. This fixes the problems with this error, which I wrote about at the beginning .. This is for posterity because no one will write how to handle it on the forums only refer to hell knows what crappy paid sites and to download hell they know what files ...
    If I wrote it in the wrong place, let the moderator move it in the right place so that others do not have to search on the Russian pages
  • #15 21597523
    kellam5b7rodney
    Level 4  
    >>20260533 .
    Thanks, the old-for-new theme works
The discussion concerns a Renault CAN-Clip diagnostic probe that is detected by the Clip software but fails to communicate with the vehicle: automatic VIN loading returns an error and manual diagnostics also fail. The issue appeared after reinstalling the computer system and using Clip v146 with a likely Chinese clone interface that previously worked normally. Participants suggest checking ignition status, reinstalling or changing USB drivers, verifying whether the system is 32-bit versus 64-bit, ensuring Clip is installed on the C: partition, and trying Windows XP or a clean Windows 7 32-bit installation. The author confirms the problem persists on another laptop, with all four LEDs lit and the probe recognized by the software, raising suspicion of a probe fault or configuration issue. Later replies mention reinstalling Clip, formatting the system, and using newer Clip versions with activation/update procedures for installation errors such as missing DLLs.
