Replacing an ordinary cigarette lighter socket with a passat b6 socket
malyszum 6156 2
  • #1 16423598
    malyszum
    it is possible to replace the ordinary socket in passat b6 with the socket from the picture? I bought a roidmi 2s and unfortunately it is not compatible with this socket, will someone help? Possibly installing a new socket in a different place, etc.
  • #2 16423631
    Vytautas_YT
    Level 30  
    Help: 128
    Rate: 297
    Sockets are rather universal and there should be no problem with replacing the current socket with the one you need.
  • #3 16423740
    andrzej20001
    Help: 1578
    Rate: 6669
    The power socket does not have a bimetallic plate, all the difference. In the lighter, the plate allows the lighter to pop out when heated. The dimensions of the tips of chargers, compressors, etc. are rather identical.
