Audi A6 C6 Radiator Fans Not Turning On: VCDS Fault Check, Fuses and Control Module Test
Audi16675 14535 2
  • #1 16508207
    Audi16675
    Rate: 17
    I have a very serious problem namely the radiator fans do not turn on.
    I've already checked:
    1. Faults with vcds
    2. I tried to enable them vcds, no reaction
    3. All fuse checked two fuse boxes under the pit, under the steering wheel and on the side of the upholstery
    4. Fans checked briefly by applying power, both of them work
    There is a control module next to the fans, is it possible to check it?
  • #2 16508584
    jacolino75
    Level 19  
    Help: 28
    Rate: 175
    PWM controlled fans from the motor controller. And do you have module power supply?
  • #3 16508606
    Audi16675
    Rate: 17
    The module has four wires, two power supplies and two ground
