Audi A4 B6: Air Conditioning Issue - Blower Not Running Despite Fuses Being Okay
Filipek1992 14142 3
  • #1 16179669
    Filipek1992
    Rate: 21
    Hello. I have a problem with my Audi and it happened now in the cold. The car stood for about 2 days in the garage, not fired, I went to the burnout and noticed that the air conditioning was not working for me. I checked the fuses are ok. I am adding a link to the video not by me, but the symptoms are identical. Please help.
  • #2 16180067
    humbel
    Help: 84
    Rate: 198
    Connect to CAN and check if any errors crash.
  • #3 16180164
    grala1
    VAG group specialist
    Help: 1495
    Rate: 5052
    Fan end, open circuit, blown fuse, blown fan control.
    There is a diagnosis on the K line, not CAN.
    Meter in hand and after 15 minutes you will know what is wrong.
    Access to the cabin fan is very simple.
    Clipboard down, three screws on the fan and you've got it out.
  • #4 16278012
    Filipek1992
    Rate: 21
    I replaced it with a new fan and it's ok thanks for your help.
