Installing Exhaust Pipe Extension for Portable Air Conditioner through Suspended Ceiling
mwac1 11637 2
  • Suspended-ceiling exhaust run may work with PVC pipe
    #1 16511987
    mwac1
    Hello, I want to install an exhaust pipe extension from a portable air conditioner. Will it be a problem if the air conditioner standing by the wall has an outlet through a PVC pipe vertically above the suspended ceiling and only above the ceiling will the pipe travel about 5-6 meters to the outside. Can anyone say if this solution will work?
    Unfortunately, I do not have permission in the premises to install an outdoor unit. I also cannot break through the wall. The only option is to use the grille / vent that is patched from the inside at this point.
  • #2 16512559
    borg77
    Help: 199
    Rate: 448
    The set for the air-conditioning should include an adapter for mounting the exhaust in the window.
    From what I can remember, the instruction recommends the shortest possible outlet pipe. Besides, a long pipe increases the air resistance at the outlet and the pipe section in the apartment will emit excessive heat.
  • #3 20983612
    peterbatley
    Installing an exhaust pipe extension for a portable air conditioner through a suspended ceiling needs careful planning and professional expertise to provide proper ventilation.
