Raspberry Pi 3 Power Supply: Motorola NU18-4057300-I3 Compatibility - 5.7V 3A 3000mA
Trustcio 6426 11
Can I use a Motorola NU18-4057300-I3 power supply rated 5.7V 3A to power a Raspberry Pi 3?
No, the Raspberry Pi 3 should be powered from a 5V micro-USB supply rated at least 2.5A, so a 5.7V adapter is not the recommended choice [#16515654][#16515786] The thread notes that 5.7V may be the unloaded voltage, which makes it even less certain to be safe to connect directly [#16515678] A later reply adds that Raspberry Pi supplies are typically 5.1V because some voltage is lost in the cable, and 5.7V could overheat the Pi’s regulator/stabilizer [#17362404] If you want to use that adapter, you would need to reduce/regulate it down to about 5V and use the correct micro-USB connection [#16515678][#17361476]
  • #1 16515639
    Trustcio
    Hello. Will the MOTOROLA NU18-4057300-I3 power supply be suitable for the Raspberry Pi 3? Data: 5.7V 3A 3000mA?
  • #2 16515654
    HD-VIDEO
    Help: 1265
    Rate: 1885
    No, it's supposed to be 5V / 2.5A with Micro USB
  • #3 16515658
    Trustcio
    And the plug cannot be converted? 2.5 And that's enough? I can see that 3A people are also buying.
  • #4 16515678
    HD-VIDEO
    Help: 1265
    Rate: 1885
    You need to solder the Micro USB plug or the cable is ready to buy.
    There is 5.7V, it is not known if the voltage was given without load.
    You can buy 3A and 10A
  • #5 16515681
    Trustcio
    So up to 5V power supply and the amperage does not matter, only above 2.5A?
  • #6 16515786
    HD-VIDEO
    Help: 1265
    Rate: 1885
    2.5A is sufficient
  • #7 17361447
    CN_wn
    Would a 5 and 2.3A power supply be sufficient?
  • #8 17361476
    keseszel
    Help: 54
    Rate: 558
    You are buying as recommended by the manufacturer. At 5.7V nothing should happen, if the amperage is too low you may have an unstable circuit, although I doubt it. I bet there is some voltage stabilization in the Raspberry. If the plug does not fit, you earn a new one, or cut the tip from a micro-USB socket. Before connecting, you check several times if you have made a mistake. The cables are insulated with heat-shrinkable sleeves, to avoid the "cocoon" you move them by, say, a centimeter. You do not cut the plugs at the very "butt".
  • #9 17362035
    CN_wn
    Thanks for the info :)
  • #10 17362404
    _jta_
    Electronics specialist
    Help: 3212
    Rate: 4259
    5.1V power supplies are used for Raspberry Pi - because about 0.1V is lost on connections (sometimes more, it depends on the cable). I guess the Pi power scheme is published? Or maybe you can find some readily available voltage stabilizer that will do about 0.5V less from 5.7V? If the Pi has a stabilizer, I don't know if it will overheat at 5.7V.
  • #11 17362432
    keseszel
    Help: 54
    Rate: 558
    0.7V is a drop on the diode and after the pain. You have 5V.
  • #12 17362495
    _jta_
    Help: 3212
    Rate: 4259
    The point is that the diode voltage drop depends on the current and temperature, so it will not be accurate. I wonder what the tolerance of these 5V is - for TTL systems it is + -5%.
The discussion centers around the compatibility of the Motorola NU18-4057300-I3 power supply with the Raspberry Pi 3. The consensus is that the Raspberry Pi 3 requires a power supply of 5V and at least 2.5A, while the Motorola supply outputs 5.7V at 3A. Although the higher voltage may not immediately damage the device, it could lead to instability or overheating. Users suggest that a voltage drop may occur in the connections, and it is recommended to use a power supply that adheres closely to the manufacturer's specifications. Modifications to the plug may be necessary for compatibility.
