[Solved] Raspberry Pi 3 B + power supply via GPIO
Ty-grysek 10569 3
  • #1 17486464
    Ty-grysek
    Rate: 269
    Can you power the latest Raspberry directly via the + 5V GPIO pins? I was a little googling and all that is true. I did that too and for a while it even worked until it stopped. However, I am not sure if the cause of the failure was elsewhere, so before I burn the next copy I prefer to ask. I will mention that RPi 3 B + has an advanced (?) Voltage regulator instead of the usual stabilizer.
    By the way, and for the future - is the power supply directly via 3.3V GPIO at stake?
  • #3 17486573
    Ty-grysek
    Rate: 269
    hindoos wrote:
    3.3V is created from 5V by a linear stabilizer.
    RPi 3 B + has no stabilizer and some voltage regulator.
    And I've already found the answer to my question. I was looking for an unknown where in Datasheet is black and white that can be powered by 5V GPIO:
    https://static.raspberrypi.org/files/product-...fs/Raspberry-Pi-Model-Bplus-Product-Brief.pdf
    So I close the topic.
  • #4 17486578
    Ty-grysek
    Rate: 269
