PLC/Automation Programmer Interview: Ladder Programming, Wiring Diagrams & Job Expectations
12879 9
What should I expect to be asked to do in a PLC/automation programmer job interview, and will I have to write a ladder program?
You may be asked either to write a short ladder program or just discuss general automation topics, depending on the company. [#16558231][#16560740][#16572198] A typical practical task is a small LD exercise, such as controlling two actuators with limit switches and START/STOP buttons. [#16558231] Interviews often also check whether you can read electrical documentation and draw a simple control circuit with a relay, limit switch, fuse, cable marking, and wire colors, or interpret I/O diagrams and sensor wiring. [#16574707][#16576497] Expect questions about industrial networks, distributed systems, HMI/SCADA, inverters, PID, NPN/PNP sensors, valve types, and sometimes even basic C/C++. [#16558231][#16572198][#16560740] Some interviewers care more about how you explain your past projects or thesis and how you handle gaps in knowledge than about memorizing complex theory. [#16560740][#16573925][#16574707]
  • #1 16558179
  • Typical PLC interview task: ladder logic with actuators and limit switches
    #2 16558231
    Kaliber PC - Service
    Help: 50
    Rate: 69
    In general, you can expect everything that can be written in a short time, but which can also assess your knowledge, e.g. I had to write a program in LD which controlled 2 actuators with limit switches + include STOP / START buttons.
    Usually it is not complicated and drawing such a program should not take more than a few (naście) minutes (because would you like to wait an hour until you write 80 lines ?? ;) ). Of course, a lot depends on how you do PLC programming.
    For this they can check your knowledge of industrial networks, controller construction or HMI etc.
    Konstantego Damrota 5, Radlin, 44-310 | Tel.: 692XXXXXX (Show) | Company Website: https://www.kaliberpc-service.pl/
  • #3 16560740
    Rkarcz
    Automation specialist
    Help: 81
    Rate: 43
    Recently I have conducted such interviews with candidates myself. None wrote the program ... :)
    I used to have several conversations and none of them wrote the program ... :)
    You usually talk about general concepts. Can anyone kuma scan the program.
    What does he know about industrial networks or about distributed systems.
    Maybe some inverters. I was asked about my thesis.
    I introduced the same thing to myself. He talks a lot about knowledge and involvement in a given project.
  • #4 16566368
    Help: 50
    Rate: 69
    This is not bad, because I had to "boast" skills at every conversation ... :P But maybe it depends on the company?
    author - how was the conversation? :D
  • #5 16572198
  • #6 16572474
    Help: 50
    Rate: 69
    Radzio M. wrote:
    My longest conversation lasted about 2 hours.
    8-O
    Dude, you must have been recruited for war, not automation. :D
    And the crux of the problem - experience. How to get them when nobody wants to hire you ...? In my case, "picking and picking" helped during the nights during technical school, but in general I know that many people have problems with the first employment ... Unless you are after IT. ;)
  • #7 16573925
    adamac2
    Help: 49
    Rate: 23
    In my humble opinion, the question from the digital, analogue c, c # and other miracles in the context of automation work is meaningless (I am speaking in the context of an integration company). And even more so folding the gears.
    If anyone has experience, let them tell what they did to what extent. If someone does not have experience, it is enough to talk about studies about their diploma thesis, usually if someone did well in college, shows a lot of optimism and is confident, he will certainly cope (he will gain knowledge).
    At least I watch it with my younger colleagues, if someone is thin, in the topics I wrote always something turns on.
  • Need for automation engineer with PC and network skills
    #8 16574328
    Rkarcz
    Help: 81
    Rate: 43
    @ adamac2 that's exactly what I meant. That's what the trial period is for - 2 weeks, 1 month, 3 months.
    I just have an employee for a 3 month trial period and it's a shook when he catches. And he had problems configuring Windows 7. Because he never did it - just another generation - he does it himself. But after a week, our installation instructions for the SCADA operator station are at your fingertips, put it in order not to waste time and not enter the same settings 3 times, pride over some scripts to automate it. And that's what this is about. I don't need a C electrician and programmer. I need automation with knowledge of PC, Windows, Ethernet networks. Programming basically only LAD. I can teach him everything by myself. The less mastered the better. No routine .. :)
  • Interviewing PLC candidates on documentation and troubleshooting
    #9 16574707
    Slwka
    Help: 10
    For me, reading electrical documentation is essential.
    Delikwent must be able to draw a simple control system, i.e. relay, limit switch, fuse, cable marking.
    Another knowledge of the colors of the wires.
    If he can understand what is drawn in the documentation and there are enough kumatas to modify the system, the rest is familiarity with programs ...
    For a friend I recommended a young man after graduation who was not able to display elements in the switchboard, but left for 3 minutes with a problem asked clever and discreet Google uncle.
    After 3 minutes he was almost ready for the subject ;) . Usually during interviews I try to drive a candidate in a topic that he doesn't understand and then leave him with a gate to get the missing information ...
    I check how it will handle the situation, the most valuable are not necessarily all-knowing with the flaps on their eyes, but those who check / ask will not hurt others, themselves and at the end of the equipment ... These are often dangerous toys ;) And how else can someone discreetly handle the situation? ;)
    The kid has been working for 1.5 years, both sides very happy. "Young" is already piloting quite a lot of projects.
    There is no rule.
    At the last conversation I was on, I had to figure out how you can use a set of devices that I saw in passing passing through the workshop (to combine the equipment that I saw with the company profile and build from it a production line according to my own concept so that it could be offered to a client),
    then I fell on a simple task like in step 7 implement the function on / off with the same input ... I dealt with the topic because irritated with my twist brazenly took out of the laptop bag I started step 7 pat a small program and started plcsim (unique recruitment face) but out of place we went to other topics, e.g. how to measure the time between presses, etc. I proposed two alternative solutions while calculating how much memory in cpu will take ...
    They were to call in 1.5 weeks after the recruitment was completed, they called after 2 days ...
    I would not call them in their place ;)
  • #10 16576497
    romulus73
    Help: 96
    Rate: 252
    I ask a delinquent what is he good at?
    I give a diagram, let him say what he sees.
    Make the scale I / O on the card show me where is the measurement center for the -1 to 6 bar transducer and 4-20mA output, and how I will realize the alarm for this transducer if I loosen the cable.
    Next, a cloth with I / O panels, BMS, inverters, basic configuration and it flows by itself.
    Rkarcz buddy, do you have time to teach? this work is not much.
    We are looking (my boss) for a human being overwhelmed with thermo-dynamics, control for chillers, ventilation, and refrigeration.
    CV for 1 month received, no such people for service, the rate is probably quite good, as you say laptop fura and komura
The discussion revolves around preparing for a PLC/Automation programmer job interview, focusing on expectations regarding ladder programming, wiring diagrams, and general knowledge. Candidates may be asked to write a simple ladder logic program, typically involving control of actuators with limit switches and START/STOP buttons. However, many interviewers prioritize discussions about general concepts, industrial networks, and project involvement over practical programming tasks. Candidates should be prepared to demonstrate their understanding of electrical documentation, control systems, and basic programming concepts. Knowledge of PLCs, C language, and the ability to troubleshoot and adapt are also emphasized as critical skills. The importance of practical experience and the ability to learn on the job are highlighted, as many candidates face challenges in securing their first positions in automation.
