Removing or Replacing Clutch Pedal's White Plastic Cable Holder in Opel Corsa B
Terazniejszy 7752 6
  • #1 16600653
    Terazniejszy
    White plastic, which is mounted on the clutch pedal, and whose task is to hold the cable - has broken, the cable works in it and after some time it rubs and breaks off.
    I found a Corsa on a road in my city, I would like to obtain this plastic.
    Question: Can it be removed from the pedal in some way or not?
    If not, how do you remove the entire clutch pedal?
    Best regards.
    Bartek.
  • #3 16600817
    Terazniejszy
    No.
    I mean the plastic part of the clutch pedal that holds the cable
    He's done for me and destroys the line
    The question is whether it can be obtained from another pedal, or is it a whole and you need to translate the entire pedal. If so, how to do it - how to unscrew the clutch pedal in the Corsa?
  • #4 16602013
    g107r
    Help: 811
    Rate: 993
    I found something like that - when I don't know, I look for solutions in pictures :)
    del
    Find yourself on the Allegro "corsa clutch pedal", they ordered to remove the link. the pedal itself is already disassembled.
    You can see that you can probably remove the pedal itself, because the whole thing is for sure. Look at the pedals what holds the pedal axle, and how to unlock it - seger? For the screws holding the pedal unit.
  • #5 16602140
    Terazniejszy
    Thanks for the help
    Last question - which side do I put the clutch cable on? From the pedal or motor side?
    I am asking in case I need to replace it
    Is it a complicated activity?
    Thanks
    Bartek.
  • #6 16602219
    g107r
    Help: 811
    Rate: 993
    Follow google as it is, adjusting it to your case https://www.google.pl/search?q=peda%C5%82+sprz%C4%99g%C5%82a+opel+corsa+b+1+0&ie = utf-8 & oe = utf-8 & client = firefox-b & gfe_rd = cr & ei = 97xyWealG4jc8AfuxJ6YDg
    There was a topic, directing to his website http://forum.opel24.com/topic/21026-w-corsie-...r-98-pekl-mi-plastik-laczacy-linke-z-pedalem/ where I think they figured out the topic of plastic, while the link to the topic died, maybe it was merged into another leading topic ... If you want, you can bury it in this forum.
    This is not engine diagnostics and repair.
    On the Opel forum, I saw to lift the pedal and remove the cable, but is it the same pedal? Another link is from the chest side.
    Here you can wait a month for someone who replaced the pedal or the pedals. It may be simple, but you have to wait for someone who did it in a corsie, and would like to share their knowledge ... You will probably do it yourself faster than you will get a satisfactory answer, so far it is probably just a "point-collecting" friendly anonymous :( and the knowing ones are reluctant, waiting for more involvement of the author-you, there are no such, or they have not read this topic yet.
    As for the link, you should also find out about the regulation, so that it would not be like with a mechanic on another forum, who said that there is no regulation, although it is, and the clutch pedal worked strangely.
    Good luck.
  • #7 16705144
    kkknc
    Help: 1915
    Rate: 6709
    You order and it brings you. Max is a week. And most often they come in 3 days.
The discussion revolves around the issue of a broken white plastic cable holder on the clutch pedal of an Opel Corsa B, which is causing the clutch cable to wear out. The user seeks advice on whether this plastic part can be removed from another pedal or if the entire clutch pedal needs to be replaced. Responses suggest that the plastic part is likely integral to the pedal assembly, and removing the entire pedal may be necessary. Users recommend checking online marketplaces for replacement parts and provide links to resources for further assistance. Additionally, there are inquiries about the correct installation of the clutch cable and whether the replacement process is complicated.
