Arduino UART Communication: Sending & Receiving Data from 10 Sensors (Digital & Analog) to LCD
pyton 5799 17
How can I send readings from 10 sensors over UART between two Arduinos so the receiver knows which value belongs to which sensor?
Send the sensor data as a clearly defined frame instead of ad hoc strings: include an easy-to-detect start byte or prefix, put the values in a fixed order and size, and add a checksum so Arduino2 can verify the frame before using it [#16624459] For beginner-friendly debugging, you can start with ASCII text fields separated by a delimiter and a line ending, then map received values by array index on the receiver, but keep the format strictly defined [#16624339][#16624509] If some sensors are only 0/1, pack them into individual bits, and for analog values send scaled integers or separate bytes rather than long decimal text to reduce traffic [#16621505] If you prefer not to design your own format, use an existing Arduino serial library/protocol such as MySensors serial API or EasyTransfer [#16621656][#16632006]
  • #1 16621485
    pyton
    Help: 31
    Rate: 30
    I would like to do this: I want to establish communication between 2 devices after UART, e.g .:
    Sensors> Arduino1> UART> Arduino2> LCD
    While there is no problem with sending the command for Arduino1 to Arduino2 ... I don't know how to send variables ..
    For example, I have 10 sensors, some output gives digital status 0 or 1 rest analog value.
    I don't know how to send all data after UART and how to receive it so that it is clear which value comes from which sensor.
    It seems to me that each sensor should be assigned a "name" send from Arduino1 after UART and simply cut it when writing to a variable in Arduino2, then send on LCD?
    If there is something in it, I would ask for a link or a place where I can find information about trimming such a string, or how to look for it?
    The data string may look like:
    t1: 32.25 h1: 75.75 t2: 45.55 h2: 40.00 t3: 80.88 h3: 0 h4: 1
    that is: temp1weigh
    I would just like to send the data from the sensors remotely and display on another LCD.
    best regards
  • #2 16621505
    dondu
    Help: 1292
    Rate: 809
    You combine well. Develop your own protocol the way you like.
    Equally, instead of values based on ascii, you can send bytes without tags t1, h1, etc., i.e. develop your own byte data frame, where you will know what each subsequent byte means. To such a frame you can also add a characteristic constant prefix (a byte or several) after which you will recognize the beginning of the frame and finally a byte of some checksum.
    In such a frame, you can additionally reduce the number of bytes transferred by using individual bits for information that is only 1 or 0.
    Instead of sending 8 bytes e.g. t1: 32,25
    send two bytes with values 32 and 25
    and because they will be the first two bytes after the prefix, you will know that it is the integer value and the decimal value of sensor t1, respectively.
    The next bytes will concern the h1 sensor, ... etc.
  • #3 16621656
  • #4 16624339
    ditomek
    Help: 24
    Rate: 230
    I propose a format that I have successfully used for many years myself.
    They are bytes separated by a special character - for me it is a colon.
    for convenience when starting the message can be completed with some other character used only once.
    the end of the message is standard for arduino \ n
    stick binaries in bytes or wordy as you like.
    Remember that analog measurements with decimal places can be sent without this decimal point and inserted into the value on the receiver side.
    After receiving such a string of characters, I put the received numbers in the receiving table. array indexes correspond to the location of the number.
    Do not unnecessarily send additional information what is what because it only slows down the transmission.
    Once you've mastered it, you can start minimizing the amount of data sent, e.g. by switching to hexadecimal code, you can try to generate checksums and ultimately transmit data in binary.
  • #5 16624351
    JacekCz
    Help: 760
    Rate: 1460
    Binary and textual protocols are a terrible project. What if the byte has the character meaning of a colon?
    Harmful advice.
    Can you say what you mean?
    You can't understand what you want to say. First you write "send bytes", then "to save space convert to hexadecimal" which doubles the volume. This is some gibberish.
    I will add for ease that if you could distinguish numbers from numbers, and bytes from characters would make progress.
  • #6 16624407
    ditomek
    Help: 24
    Rate: 230
    It's something like this:
    255: 255: 255:
    As you can see, there are bytes between colons but sent as text.
    When you just start such a protocol, this presentation is the most convenient.
    Then you can send 255 as FF - you save one character for three-digit numbers.
    Similarly, if instead of single bytes you want to send two byte numbers like wordy etc.
    Instead of: 65535: 65535: after the series you send: FFFF: FFFF:
    Maybe now I will be more understandable :-)
  • #7 16624439
    tmf
    Help: 2090
    Rate: 2203
    255: 255: 255:
    It's not so beautiful. While if you send the whole thing as text, this colon has some sense (except that you can't tell the beginning of the frame), you can't convert it to a binary form. This is what JacekCz mentioned - what if the binary representation of a given data has an ASCII colon code?
  • #8 16624445
    JacekCz
    Help: 760
    Rate: 1460
    255: 255: 255:
    Stopgap. Nail the kennel to the curve of the shed. And that the shack has decayed boards, let's support it with a pole.
    You combine some horrendous protocol, and therefore you combine that you haven't asked yourself elementary questions about what it really is (textual or binary), what is the "contract" between the transmitter and the receiver, for example, dedicated / universal use, the recipient is a machine or a human, etc.
    Secondly, once again, "I will invent a better, more round wheel than others have invented." Thirdly, words are important, as one speaks imprecisely, one always makes imprecision (only one-way implication)
    After many years, we add ideology to the practice curve, that's our nature.
  • #9 16624459
    arturt134
    Help: 76
    Rate: 24
    In general, any well described protocol will do its job. It is best to create such a protocol from the beginning for your own device (contrary to appearances, it will not take much time), because then you can take into account the specificity of a given device (e.g. frequency of data transmission, amount of data), specificity of the transmission channel (bandwidth, reliability of data delivery, delays) as also your own preferences. It can be a protocol based on sending ASCII characters, but it can be based on sending binary values (I personally prefer the latter solution)
    It's important to:
    - the beginning of the data frame is easy to detect by the receiver (it can be a fixed start byte, 4-byte line break, etc.)
    - easy-to-specify frame size - either explicitly (e.g. sent immediately after the start byte), or by defining the end of the frame (stop byte, 4-byte line break, etc.), or both at once.
    - the correctness of the data in the frame is easy to check (checksum, according to the standard CRC algorithm or even the sum of all modulo 256 bytes)
    - exactly described meaning of data bytes transmitted in the frame (location, size, range of valid values)
  • #10 16624473
    grko
    Help: 247
    Rate: 141
    Creating your own protocol is a very bad idea in 98% of cases. There are so many binary / text existing protocols that it is not worth creating another. Own protocol generally means problems with imple- mentation errors, lack of ready-made tools, integration problems etc. I do not recommend.
  • #11 16624488
    arturt134
    Help: 76
    Rate: 24
    A proprietary protocol generally hampers the life of competitors .... Of course, sometimes devices must support standard protocols (e.g. Modbus), because these are the market requirements, but all service commands are sent in non-standard and implicit protocols. Besides, somehow I can't imagine implementing Modbus to send 4 bytes of data between two devices designed by me and not cooperating with other devices from other manufacturers. It's just using a cannon to kill a fly.
    In the previous post I tried to clarify what a good transmission protocol should have. Instead of writing your own, you can take it ready, maybe my description will help in choosing the best one.
  • #12 16624509
    ditomek
    Help: 24
    Rate: 230
    @JacekCz what your post is for You want to laugh at me or help a friend solve a problem.
    I have the impression that you are more interested in the first one and do not understand why.
    What I put in the post is just a fragment of what I have been successfully using in my projects for years. Does it irritate you that it works?
    The full format is similar to modbus (I also use division into functions, data blocks and error checking) basically the only difference is the characters separating the fields and the way the checksum is calculated. And that the project is mine, I have no restrictions on the format.
    Sure I could reach for a ready modbus library but then I wouldn't learn anything.
    In addition, My protocol is more friendly because I do not use hexadecimal number coding and in any terminal emulator you can see what's going on.
    This is really helpful during startup.
    It is very convenient to process this data in python because there are ready functions for exploding data and placing them in an array.
    In fact, you only need three lines of code.
    But it would probably be better if I caught something from the others or reach for cash ... standard thinking of an arduin.
    @tmf a colon separates fields, between the colon there are 1 to 3 "0-9" characters making up one number - exactly a byte
    It is not possible that the colon will become a number because I send ascii characters. The beginning of the frame is from "=", the end is immortal \ n
    I don't understand your fears.
  • #13 16624622
    JacekCz
    Help: 760
    Rate: 1460
    Exactly
    Right now, there is a thread about MQTT at uK next to the poem, I support it and I even read ambitiously, I couldn't help. The authors of the new implementation "forgot" to explicitly state that there is a limit to the number of variables.
    FIRST with any reliable protocol is a strict and full specification.
    Specifications not offend, but amateur, it's a shot in the knee if you want to convince to the protocol.
    edit: plus problems reported by colleagues.
    As for faith, "works for me." It works in the hands of the author - we probably know it - still not enough, what is more, in the hands of the same author, when he returns to the project after a long time, in intuitively changed conditions (especially without documentation or with inaccurate documentation). The same person sitting down to the code from X years ago is basically like a second independent programmer, with all the resulting problems.
    This is the essence of mature or professional software, use a recognized library THIS IS NOT A SHAME. there is some (useful) hardship in it, because you have to get into it, feel better than you do (sometimes you also have to have a critical opinion about it), etc.
    I am not an arduinist and the style of doing "libraries" is a disaster.
    I have my sociological observation. In the world of PHP / JS is the point of glory writing in your own way again, something that has repeatedly proven implementations. You can guess a lot about psychology, maybe it's too weak to understand the library extension points, APIs, etc. ... I feel undervalued, etc ...
    In the Java world, such a programmer would be killed by laughter, a completely different style there.
    As we are talking about sociology: in the arduino world one writes "I have such codes" which are pasted without understanding.
    In conclusion: "write your own way" psychology occurs only in some IT segments
  • #14 16624635
    tmf
    Help: 2090
    Rate: 2203
    You mix. If the protocol is completely based on ASCII then there is no problem. You wrote that you can send this data in binary form - you can't do it without special solutions. Currently, we have ready for almost every occasion and the only thing you need to do is choose the right existing protocol that best meets our expectations. Inventing the wheel again brings nothing.
    Added after 5 [minutes]:
    Supporter of "Security through obscurity"? It has been laughed at many times. You will clear a sensible protocol once, the introduction of weirdos will be more difficult for the author of the project than for the person who wants to disagree. You need to make life harder for your competition - from this you have protocols with data encryption, authentication, etc. Ready solutions have at least security analyzes done. In an author's solution, it is usually the case that the author believes in the security of his solution, without having any evidence for it.
  • #15 16624645
    dondu
    Help: 1292
    Rate: 809
    There is only one right way.
    Each case is different and one cannot claim to be one protocol or another. The designer decides about this fact, because only he has full information about the project, including the restrictions it must overcome. Therefore, in one case he will decide to use ready-made protocols, and in another he will create his own.
    The argument that there is a lack of ready-made tools, while the programmer is fluent in C (or other universal) is unsuccessful because he is able to write his own tool quickly. Similarly with implementation errors.
    Therefore, let's finish the discussion in this area, focusing on prompting the author who has not spoken yet.
    In addition, the author is a beginner and it is worth helping him create his own protocol to broaden his skills, which in the future will allow him to consciously choose the optimal solution for each subsequent project.
  • #16 16624696
    ditomek
    Help: 24
    Rate: 230
    @tmf I do not mix, I wrote to the author that after mastering the art of sending messages, ascii can switch to binary transmission.
    Read my post again and I'm sure everything will be clear now.
    In fact, maybe I used too many mental shortcuts and now I have to explain everything ...
    for me EOT
  • #17 16631839
    pyton
    Help: 31
    Rate: 30
    Thank you very much for the hints - for the moment I have to let go of the topic ... if I find a moment I will come back to it and probably if something does not work I will ask :)
    Thank you so much again.
✨ The discussion revolves around establishing UART communication between two Arduino devices to send and receive data from ten sensors, both digital and analog, to an LCD. The main challenge is how to effectively transmit sensor data, ensuring clarity on which value corresponds to which sensor. Various suggestions include developing a custom protocol, using ASCII or binary formats, and employing delimiters like colons to separate values. Some participants advocate for creating a unique protocol tailored to the specific project needs, while others caution against this, recommending existing protocols for reliability and ease of implementation. The importance of a well-defined data frame, error checking, and the potential for future data logging are emphasized. The author expresses gratitude for the insights and indicates a willingness to revisit the topic later.
TL;DR: Moving 10 sensors over UART? "There is only one right way." Start with a simple frame (start, data, checksum), pick ASCII or binary, and parse deterministically on the LCD side. [Elektroda, dondu, post #16624645]
Why it matters: Clear framing prevents misreads, reduces bandwidth, and makes two‑Arduino sensor-to-LCD links reliable for beginners and pros.
How do I send mixed digital and analog values between two Arduinos over UART?
Define a simple protocol. Add a start byte, list sensor values in a fixed order, include a length or end marker, then a checksum. The receiver scans for the start, verifies length/checksum, and maps bytes to sensors before updating the LCD. [Elektroda, arturt134, post #16624459]
Should I use ASCII or binary for Arduino-to-Arduino sensor data?
ASCII is human-readable and easy to debug with a terminal. Binary uses fewer bytes and can combine multiple booleans into bit fields. Choose based on bandwidth and complexity. “Develop your own byte data frame” when efficiency matters. [Elektroda, dondu, post #16621505]
How do I label which value comes from which sensor without sending tags like t1/h1?
Skip text tags. Use a fixed byte layout: for example, bytes 1–2 = t1 integer/decimal, bytes 3–4 = h1, then t2, h2, etc. Document the order once and parse by position every time. [Elektroda, dondu, post #16621505]
What beginner-friendly text format works for my first prototype?
Use colon-delimited ASCII with clear framing. Example: =255:128:1:75\n. The '=' marks start, colons separate fields, and a newline ends the frame. Parse tokens into an array by index, then display. [Elektroda, ditomek, post #16624509]
What if my chosen delimiter appears in binary data?
That’s an edge case that breaks parsing when migrating from text to binary. A byte in binary may equal the ASCII code of your delimiter, corrupting frames. Keep binary framed independently from textual delimiters. [Elektroda, tmf, post #16624439]
Should I invent my own protocol or reuse a standard?
Both are valid. Standards ease integration, while a custom, well-documented frame can fit your device and teach foundational skills. “Each case is different,” so pick what meets your constraints and skills. [Elektroda, dondu, post #16624645]
Is there a ready-made Arduino library to transfer structs reliably?
Yes. EasyTransfer lets two Arduinos send structured data without designing a parser from scratch. It’s popular for quick, reliable field transfers between boards. [Elektroda, uzi18, post #16632006]
Can I reuse an existing serial home‑automation protocol?
Try the MySensors Serial API used by Domoticz gateways. It defines message types and topics so you can log or route measurements later with minimal rework. [Elektroda, Anonymous, post #16621656]
How do I add start, size, and checksum to a frame (quick how‑to)?
  1. Transmitter: send START, then LEN, then payload bytes, then CHECKSUM.
  2. Receiver: wait for START, read LEN, buffer payload, verify CHECKSUM.
  3. On success: parse fields into variables; on failure: discard and resync. [Elektroda, arturt134, post #16624459]
How can I compress digital 0/1 sensor states to save bytes?
Pack them into bits. For eight digital sensors, use one byte where each bit represents a sensor. Send that byte once per frame instead of eight separate values. [Elektroda, dondu, post #16621505]
What’s an efficient way to send decimals like 32.25?
Avoid sending the dot. Send two bytes: the integer part (32) and the fractional part (25), or scale the reading as an integer (e.g., 3225). Decode on the receiver before display. [Elektroda, dondu, post #16621505]
How should the LCD-side parser map incoming values to the screen?
Tokenize the received line into an array. Use array indices as stable positions for sensors and print them to the LCD. This keeps parsing simple and fast. [Elektroda, ditomek, post #16624339]
Any security cautions when rolling my own protocol?
Custom formats can feel safe but lack vetted analysis. Prefer proven mechanisms for authentication and encryption when exposure matters, and keep formats unambiguous. [Elektroda, tmf, post #16624635]
Is switching to hexadecimal text actually smaller than decimal?
Hex can shorten large values in text (e.g., 255 → FF), but it still doubles payload versus true binary. Use hex only for readability; use binary for bandwidth. [Elektroda, JacekCz, post #16624351]
Any quick debugging tips for bring‑up?
Start with ASCII frames you can watch in a terminal. “In any terminal emulator you can see what’s going on,” and Python can split fields into arrays in minutes. [Elektroda, ditomek, post #16624509]
