Opel Corsa C 2001: Locked Trunk Lid, Actuator Issue, Remote Control & Fuse Protection
henio 123 7128 2
  • #1 16628753
    henio 123
    Rate: 144
    Hello, the fault is as in the topic The boot lid has been opened yesterday. The doors and the fuel filler open and close from the remote control. The flap actuator does not work. Does this actuator have a separate protection on the fuses?
  • #2 16628785
    moto-kord
    Help: 137
    Rate: 505
    Have you checked the cables in the grommet?
  • #3 16668819
    henio 123
    Rate: 144
    The reason for the fault was the gap between the flap lock button and the lock itself. No plastic connector at the intermediate connector of the lock. The defect is removed. I consider the topic closed.
