Opel Corsa C Central Locking System: Remote Control, Emergency Lights, No Fuse Found
stramik 85433 3
  • #1 6772041
    stramik
    Hello!
    I have a problem with the central locking system on the Corsa C. It suddenly stops working. When you press the button on the remote control in the key, only the emergency lights flash, but the central one does not work. When I use the key, the central one also does not work. I don't know what's going on anymore. I did not find fuses from the central station, only the transmitters that I have already checked, but they are good. Anyone have any suggestions what could it be? The central one is powered from there. Does electricity go through this body controller or what? There are no fuses there?
  • #2 7245456
    marian_44
    Rate: 58
    Hello, I have a similar problem, have you already solved it? And which is the central locking relay? Thank you in advance for your answer.
  • #3 8313328
    affgaan
    Rate: 10
    Hello, I had the same problem, the blinkers were on, while the central one did not close, it turned out that it was a fuse, if someone else had the same problem below, there are fuse diagrams in my case, Corsa C 2001 1.7d it was fuse 13 described as anti-theft protection (also a fuse 19 is identically described)
    Opel Corsa C Central Locking System: Remote Control, Emergency Lights, No Fuse Found Opel Corsa C Central Locking System: Remote Control, Emergency Lights, No Fuse Found Opel Corsa C Central Locking System: Remote Control, Emergency Lights, No Fuse Found
  • #4 18883707
    Corsa231
    Rate: 11
    Hello, I will step on the subject, but my problem is a little different.
    I replaced the ECU in the corsie 1.0, the whole ECU set, the loop module, went and everything.
    The problem of the central lock remained, even after turning the key, it does not close the door (except for those where I turn the key)
    When replacing the comfort module with the old central one, it works but the car does not start (It is not paired with the ECU)
    How to solve this problem
