MS Outlook: Transfer Custom Folders & Contents from 2007 to 2016 - Preserve Folder Order
radd91 4893 3
  • #1 16652895
    radd91
    Hey,
    Is it possible to move folders from Outlook 2007 to version 2016? I do not mean a data file containing all e-mails, but folders and their contents that I created in Outlook 2007. Transferring the data file simply moved all received and sent messages. But I care about the order I created in the old version of the program :(
  • #3 16654215
    borg18
    Help: 8
    Rate: 37
    hmmm foders are contained in the database data file, i.e. those .pst files, connect this file to Outlook 2016 and all the folders it contains should be preserved ... I've done so many times and simply connected the new database will have separate - its trees
  • #4 16654915
    radd91
    Kasek21 wrote:
    Thanks! helped :) Below I explain what worked.
    As I wrote, the data file only moved all messages. However, the folders I had in version 2007 were not created in version 2016.
    From the tutorial that linked Kasek21, I used the instructions in the paragraph: "Moving the Outlook email profile" and only then did it bring the expected results :)
