Windows 10 Edge: YouTube Not Working, Black Screen, Facebook Video Issues, Tried Solutions
donex93 5580 3
  • #1 16661171
    donex93
    Maybe a trivial problem, although I have spent a while to solve it, but unfortunately it failed. The problem is:
    I don't have YouTube videos on my egde browser (only black screen appears), I noticed that on Facebook I can't turn on videos even though at least the initial picture is displayed there. A site like cda.pl works without a problem - all I had to do was allow the flash player.
    What I have already tried to do:
    - I found on the forum that I should include:
    Use programmable rendering instead of GPU rendering - nothing helped.
    - I cleaned everything with a cleanser
    - I changed the "use flash player" option in the edge options
    - I turned off adblock
    I don't send any more ideas, so please help.
  • #2 16661191
    Kolobos
    IT specialist
    Help: 17171
    Rate: 10455
    Do you need to use this browser dummy? I don't think you could pick anything worse.
    Remove Adblock instead of turning it off.
    YT no longer uses flash player.
    What is your graphics card?
  • #3 16661202
    donex93
    When it comes to edga, I need to test something from time to time and I don't like it when it works.
    Removing the adblock did nothing.
    Graphics:
    Geforce GTX 660M and built-in HD Graphics 4000
  • #4 16661877
    mmmaras
    Rate: 36
    donex93 have you tried tossing the factory settings in the edge?
