www.cda.pl Website Issues: 404 Not Found Error, Layout Problems, Video Playback on Windows 10
lufa9999 30993 12
Why does cda.pl open in a minimal layout and show "404 not found" when I try to play videos on one Windows 10 PC, while it works normally on another?
The issue is likely caused by a bad browser profile or settings on the affected PC, not by CDA’s servers, because Pale Moon works, Firefox started working after a browser reset, and Chrome still shows the 404 error [#17199135][#17200055] Try backing up your bookmarks and resetting the browser to a clean profile [#17200044] In Chrome, also check whether sync is restoring a bad configuration; if so, delete the synchronization data from the account and recreate the profile [#17200209] One user also reported that after re-enabling Edge/Firefox they were prompted to enable Flash Player, and playback then worked [#17198535] If the problem persists, check whether Eset is involved on the affected machine [#17200209]
  • #1 17198438
    lufa9999
    Rate: 138
    For several days I have a problem with the website www.cda.pl. It opens in a minimal layout, when I try to run any movie I have a message: 404 not found: the given video was not found. I would blame it on some of their server problems and wait, but on my daughter's computer, it's nice. on both computers is Windows 10. I tried Chrome and Firefox browsers. I was scanning HitMan Pro for pests, cleaning the CCleaner system, disabling the antivirus but it did not do anything. Every other site works normally, the problem is only in cda. Will anyone help me?
    www.cda.pl Website Issues: 404 Not Found Error, Layout Problems, Video Playback on Windows 10Screenshot... 02.05.jpg (117.27 kB)You must be logged in to download this attachment.
    www.cda.pl Website Issues: 404 Not Found Error, Layout Problems, Video Playback on Windows 10Screenshot.. 02.jpg (103.38 kB)You must be logged in to download this attachment.
  • #2 17198451
    KSRhaziel
    Level 36  
    Help: 271
    Rate: 275
    1. Close other cards.
    2. Clear the browser cache.
    3. Update your browser.
    4. Turn off AdBlock.
    What effect?
  • #3 17198453
    lufa9999
    Rate: 138
    Nothing, it did not change. I did it both in Chrome and Firefox.
  • #4 17198535
    tad_reula
    Help: 18
    Rate: 43
    Install the Pale Moon browser - after entering the address of the page from the image, he started right away. (A song about a wild boar.) I was also writing to EDGE and Firefox, it just went on and on. After re-enabling EDGE and Firefox browsers I received a message to enable Flash Player - I did it and now it is playing correctly. Try Pale Moon - he started right away. I will add that I have different ad blockers connected and works. The system is W10 Home.
  • #5 17198549
    keseszel
    Help: 54
    Rate: 558
    Closing other cards will not do anything.
    Clearing the browser cache - maybe, but I doubt it.
    Browser update - doubts.
    Adblock - possible, but I doubt it too.
    I bet that you have added to some strange list address.
    Do you use Opera - like on other browsers? The fact that you turned it on was ok. But give info what happened - not found?
    Smash the FRST proforma. Give results.
    CCCleaner is such a powder for the pimple, I have not used HitMan. I write based on my own experience, I can be wrong.
    I do not use operas - indigestion for me.
  • #6 17199135
    lufa9999
    Rate: 138
    Pale Moon walks correctly. Firefox and Chrome lime. In Firefox, it is the same as in Chrome: 404 not found. But for the daughters of the laptop, both Chrome and Firefox correctly open the cda.
    I'm throwing the FRST report.
    Additi..txt (50.04 kB)You must be logged in to download this attachment.
  • #7 17199790
    RADU23
    Help: 2428
    Rate: 1732
    The FRST.txt file you need.
  • #8 17200006
    lufa9999
    Rate: 138
    That's right, I'm sorry, I'm throwing in.
    FRST_02-05....05.57.txt (868.89 kB)You must be logged in to download this attachment.
  • #9 17200023
    RADU23
    Help: 2428
    Rate: 1732
    Open a notebook and paste the content:
    FF HKLM-x32 \ ... \ Firefox \ Extensions: [{F003DA68-8256-4b37-A6C4-350FA04494DF}] - C: \ Program Files \ Logitech \ SetPointP \ LogiSmoothFirefoxExt => not found
    S3 BcastDVRUserService_25eb1; C: \ WINDOWS \ system32 \ svchost.exe [51288 2018-04-12] (Microsoft Corporation)
  • #10 17200038
    lufa9999
    Rate: 138
    Nothing helped unfortunately ...
  • #12 17200055
    lufa9999
    Rate: 138
    I did it. Both in Firefox and chrome. In Chrome unchanged, continue the same problem, and in Firefox did it, it opens the page correctly.
  • #13 17200209
    Kolobos
    IT specialist
    Help: 17171
    Rate: 10455
    In Chrome, log in to your account and sync settings from it? If so, delete the synchronization data from the account and once again the profile from the disk.
    Check also after uninstalling Eset.
The user is experiencing issues with the website www.cda.pl, encountering a "404 Not Found" error and layout problems on their Windows 10 computers while using Chrome and Firefox. Despite attempts to clear browser cache, disable AdBlock, and scan for malware, the issue persists. A suggestion to use the Pale Moon browser resolved the issue for some users, while others found that enabling Flash Player in Edge and Firefox allowed video playback. The user reported that the site works correctly on their daughter's laptop, indicating a potential configuration issue on their own devices. Further troubleshooting steps included resetting browser settings and checking synchronization settings in Chrome.
TL;DR: 2 of 3 browsers failed with "404 not found"; "Pale Moon walks correctly." For Windows 10 users seeing minimal layout and cda.pl video errors, start by resetting Chrome/Firefox and testing without extensions. [Elektroda, lufa9999, post #17199135]
Why it matters: It helps Windows 10 users quickly fix cda.pl video playback and layout issues without chasing server problems.
Why does www.cda.pl show “404 not found” on Windows 10 when other sites work?
Because the failure is isolated to cda.pl, root causes point to the browser environment, not Windows. The reported minimal layout and “404 not found” align with blocked scripts, corrupted cache, or a broken profile. Other sites working and another PC succeeding rule out a provider outage. Start by cleaning cache, disabling extensions, and testing a fresh profile. [Elektroda, lufa9999, post #17198438]
What immediate steps should I try in Chrome or Firefox?
Try these quick checks before deeper fixes. Close other tabs. Clear the browser cache. Update your browser to the latest build. Disable AdBlock or other content blockers and retest. As one helper said, “Turn off AdBlock.” Verify after each step so you know what helped. [Elektroda, KSRhaziel, post #17198451]
How do I reset Chrome safely and test cda.pl?
Do a clean reset and isolate extensions.
  1. Back up bookmarks to a file.
  2. Reset Chrome settings to default, creating a fresh profile.
  3. Test cda.pl in Guest or Incognito, with no extensions. As advised: “Make a copy of the Chroma bookmarks to the file and then reset the browser.” [Elektroda, RADU23, post #17200044]
Chrome still broken after reset — what next?
Clear cloud sync and rule out security software. In Chrome, delete sync data from your Google account, then remove the local profile and retest before signing in. If you use ESET, uninstall it temporarily and check playback. Reinstall after testing. These steps target cloud-resynced corruption and AV filtering. [Elektroda, Kolobos, post #17200209]
Firefox or Edge asks for Flash — should I enable it?
Yes, if prompted on that PC. One user restored playback on two browsers by enabling Flash in Edge and Firefox. They wrote to “enable Flash Player” and reported it “is playing correctly” afterward. Enable it only for testing, then tighten permissions. This confirmed a component requirement on that setup. [Elektroda, tad_reula, post #17198535]
Why does Pale Moon work when Chrome and Firefox don’t?
Pale Moon uses a separate profile and add-on stack, avoiding the corrupted environment. The OP confirmed, “Pale Moon walks correctly,” while Chrome and Firefox failed with 404. That contrast strongly indicates a browser-profile, extension, or component issue, not a network problem. Use Pale Moon only as a diagnostic, then fix your main browser profile. [Elektroda, lufa9999, post #17199135]
Can AdBlock or similar extensions trigger 404 on cda.pl?
Yes, content blockers can disrupt scripts and media hosts. Disable AdBlock or similar extensions and retest the page. Keep them off while troubleshooting, then re-enable selectively. This helps isolate extension interference as a root cause. “Turn off AdBlock.” [Elektroda, KSRhaziel, post #17198451]
It works on my daughter’s laptop but not mine — why?
Different machines often have different browser profiles, extensions, or security software. The thread reported one Windows 10 PC failing while another worked fine on the same site. That points to a local browser or security configuration issue. Compare extensions, AV, and media settings between the two systems. Align them, then retest. [Elektroda, lufa9999, post #17198438]
Should I run FRST logs for deeper analysis?
Yes, when basic steps fail. A helper requested the FRST.txt diagnostic log to investigate system and browser entries. Generate the report and share it for targeted cleanup instructions. This approach catches stubborn profile hooks or services. [Elektroda, RADU23, post #17199790]
Could antivirus software be blocking videos on cda.pl?
Yes. Security suites can filter web traffic and break embedded players. One helper advised uninstalling ESET temporarily and retesting. If playback returns, adjust ESET web filtering or exclusions, then reinstall. Isolating AV influence prevents repeated breakage after resets. [Elektroda, Kolobos, post #17200209]
The site loads with a minimal layout — how do I fix that?
A minimal layout suggests blocked styles or scripts. Clear the browser cache. Disable extensions and reload the page. Test in a clean profile or another browser to confirm. If the alternate browser loads normally, reset the affected browser’s profile. This addresses corrupted cache or interfering add-ons. [Elektroda, lufa9999, post #17198438]
What ultimately worked in this thread?
Firefox recovered after a full reset, and cda.pl opened correctly. Chrome remained unchanged on that PC after the same steps. This highlights an edge case where reset alone didn’t resolve Chrome. Use the working browser while you continue diagnostics. [Elektroda, lufa9999, post #17200055]
