Choosing 40 Inch TV for 3x6 Room, 2 People, Full HD, Smart, Good Sound, Samsung LE32S81BX / XEC
kuczka76 4860 18
Which 40-inch Full HD smart TV should I buy for a 3x6 m room, viewed from about 2 meters, with UPC cable and decent sound?
The safest recommendation from the thread is the Samsung UE40K5672, or the UE40K5600 since they are the same base model with the same matrix and software [#16682136] [#16684201] It was described as a good Full HD VA TV with good contrast and good blacks, and the K series is 2016 while the M series is 2017 [#16682136] If you want alternatives, the thread also mentions the Samsung UE40J6240 as theoretically the best option, with the UE40K5572SU as the second choice and definitely 60 Hz [#16673475] For Samsung’s 2017 M lineup, the 40-inch M55xx was already withdrawn, while the 40-inch M50 was sold as the UE40M5000, and you were advised to check the exact Smart TV platform because small budget models may not always have full smart features [#16672906] The MU61xx was considered okay (VA, 60 Hz, HLG), but another opinion was that for a 40-inch set at about 2.2 m it is not worth overpaying [#16675396] [#16675464] [#16675510] [#16675579]
  • #1 16671900
    kuczka76
    Rate: 44
    1. How big is the room in which the TV is to be located? 3x6
    2. How far are we from the TV screen? 2 meters
    3. How many people sit in front of the TV? 2
    4. Are we sitting in front of the screen or also sideways to the screen? Mostly straight ahead
    5. Should the TV stand or should it hang? hang
    6. How does the sun shine in the room? west side that is towards evening
    7. What kind of TV do you currently have? samsung 32 inch model LE32S81BX / XEC
    8. What do we want the TV to have? full hd, smart TV internet to make it flicker well, good sound
    9. What signal will be connected to the TV? UPC cable
    10. What devices? laptop, smartphone
    11. How many hours a day should the TV work? 6-8
    12. Does it happen that you watch only one program for several hours? Yes
    13. What kind of programs do you watch the most? sports, music, movies
    14. Are you going to surf the internet? Yes
    15. Are you going to play games - if so, how many% a day? no
    16. Brand Preference? No
    17. Size preferences? 40 inches and nothing else
    18. What annoys you in TV sets? Long switch-on
    19. Do you watch more in the evenings or during the day? in the evenings
    20. To what maximum amount do you plan to purchase? max 2500
    21. How often do you replace televisions at home? bought 8 years ago and still plays today
    22. Do you use internet applications often? [/ b] YouTube
    A 40-inch TV maximum 93 cm because that's the wall on which it will hang.
    Necessarily Smart TV WIFI and Full HD.
  • #2 16672828
    Ludwik XVI
    Help: 1325
    Rate: 788
    FHD, 60Hz, VA
    The Samsung M55xx series makes sense - well priced for 2017
  • #3 16672858
    kuczka76
    Rate: 44
    Can you provide a closer model?
    Ludwik XVI
    Help: 1325
    Rate: 788
    I see that Samsung has withdrawn the 40 inch model from the M55 series and only 43 inch is available.
    However, the M50 series is 40 inches, i.e. SAMSUNG UE40M5000
    See also the interesting SONY KDL-40WE665 or SAMSUNG UE40KU6400.
    Always check what type of smart is on the TV, because in these small, budget models it is sometimes not.
  • #5 16673010
    kuczka76
    Rate: 44
    I will not get this first Samsung anywhere, the old model is unavailable everywhere. However, the next two are, I will read the opinions and see how they differ.
    Ludwik XVI
    Help: 1325
    Rate: 788
    Theoretically the best Samsung UE40J6240 - although I do not know if it also has 120Hz matrices like the bigger brother, i.e. 60J6240.
    In the second order, Samsung UE40K5572SU (here is definitely 60Hz)
  • #9 16673780
    kuczka76
    Rate: 44
    Comparing both models in the latter Samsung UE40K5572SU is better Samsung Tizen 2016 in the former is 2015 and this will probably speak in favor of buying the Samsung UE40K5572SU. Unless I missed something important, please tell me.
    Added after 1 [hours] 49 [minutes]:
    Unfortunately, they do not have it in any store ...
    Added after 14 [hours] 35 [minutes]:
    I found such a model, someone can say something about it http://www.samsung.com/pl/tvs/uhd-mu6102/UE40MU6102KXXH/
  • #10 16675396
    Ludwik XVI
    Help: 1325
    Rate: 788
    MU61xx is pretty ok.
    It has HLG support, VA matrices, 60Hz.
  • #11 16675464
    kuczka76
    Rate: 44
    I was just in one of the TV stores and the seller clearly advised me not to MU61 xx because it will not be used on 40 inches and said that it is a pity to overpay
  • #12 16675510
    Ludwik XVI
    Help: 1325
    Rate: 788
    It all depends on how close you sit to the TV :)
    Well, but if you were to pay a lot, it actually doesn't make sense.
  • #13 16675579
    kuczka76
    Rate: 44
    2.2 meters from the TV I'm confused about what to buy ?
  • #14 16682079
    kuczka76
    Rate: 44
    I think I will decide on this model SAMSUNG UE40K5672 someone some opinions?
  • #15 16682136
    Ludwik XVI
    Help: 1325
    Rate: 788
    kuczka76 wrote:
    SAMSUNG UE40K5672 something any opinions?
    Good FHD model for VA, good contrast, good black.
    K is the 2016 series, M is the 2017 series.
  • #16 16684153
    kuczka76
    Rate: 44
    Thank you for your answer and if you can still take a look and suggest what will be a better choice
    Samsung UE40K5600 or the one you already described Samsung UE40K5672?
  • #17 16684201
    Ludwik XVI
    Help: 1325
    Rate: 788
    This is the same. The base, i.e. the matrix and the software, are the same.
    They may differ in terms of the sales channel, housing color, number of connectors, etc.
  • #18 16684214
    kuczka76
    Rate: 44
    Thank you Ludwik
  • #19 16686432
    kuczka76
    Rate: 44
    They actually differ only in billing and decoder
The discussion revolves around selecting a suitable 40-inch TV for a small 3x6 meter room, primarily for two viewers sitting 2 meters away. The user seeks a Full HD smart TV with good sound quality, currently using a Samsung LE32S81BX/XEC model. Recommendations include the Samsung UE40M5000, UE40K5572SU, and UE40K5672, with considerations for smart features and matrix types. The Samsung MU6102 was also mentioned but advised against due to its unsuitability for the size. The conversation highlights the importance of matrix quality and smart TV capabilities, particularly for sports and movies.
TL;DR: For a 40-inch TV viewed at 2–2.2 m, a 60Hz VA panel with Smart features fits best; “MU61xx is pretty ok.” [Elektroda, Ludwik XVI, post #16675396]
Why it matters: This FAQ helps shoppers pick a 40-inch, Full HD/Smart TV with good sound for small rooms and evening viewing.
What’s the best 40-inch Samsung pick here?
Samsung UE40K5672 stands out as a good Full HD VA option with strong contrast and black levels. “Good FHD model for VA, good contrast, good black.” [Elektroda, Ludwik XVI, post #16682136]
Are Samsung UE40K5600 and UE40K5672 actually different?
They share the same panel and software base. Differences are mainly sales channel, color, or connector count. “This is the same.” [Elektroda, Ludwik XVI, post #16684201]
Is the MU6102 (MU61xx) worth considering at 40 inches?
Yes, MU61xx is noted as “pretty ok,” with VA, 60Hz, and HLG support. Choose it if pricing is close to FHD models. [Elektroda, Ludwik XVI, post #16675396]
Will I notice UHD benefits at 2.2 m on a 40-inch screen?
Value depends on distance and price. “It all depends on how close you sit,” and overpaying makes little sense if you sit farther. [Elektroda, Ludwik XVI, post #16675510]
How many hours of daily use are planned, and is that okay?
Planned use is 6–8 hours daily with long single-program sessions. Choose a model comfortable for extended viewing. [Elektroda, kuczka76, post #16671900]
What devices and connectivity should I plan for?
The setup includes UPC cable, laptop, and smartphone, plus Wi‑Fi Smart apps like YouTube. Ensure enough HDMI and Wi‑Fi. [Elektroda, kuczka76, post #16671900]
Is a 40-inch screen safe for a 93 cm wall space?
Yes if the set’s width fits under 93 cm. Confirm exact dimensions on the product page before buying. [Elektroda, kuczka76, post #16671900]
How do I decide between UE40K5600 and UE40K5672 quickly?
Use this 3-step check:
  1. Compare HDMI/USB counts for your gear.
  2. Pick your preferred bezel color/stand finish.
  3. Buy the better-priced, in-stock unit. Both share the same core hardware. [Elektroda, Ludwik XVI, post #16684201]
Why did a salesperson say MU61xx isn’t worth it at 40 inches?
At 40 inches, UHD gains shrink with distance. If the price jump is large, it’s not cost-effective. “It doesn’t make sense.” [Elektroda, Ludwik XVI, post #16675510]
Any edge cases I should watch for when shopping online?
Some 40-inch listings hide that a model lacks Smart OS. Verify “Smart TV/Tizen” and Wi‑Fi before purchase to avoid returns. [Elektroda, Ludwik XVI, post #16672906]
