Ford Focus II 1.6 - No power, the car does not burn on all cylinders
osliczka 13515 8
  • #1 16679830
    osliczka
    Rate: 169
    Hello, I have a big problem with the car.
    Ford Focus II 2007. 1.6 petrol engine.
    The car has very strange symptoms. Walks cold for a minute, approx.
    After warming up at idle, it works as if it does not smoke on all cylinders, the ignition can be clearly heard from the exhaust. After adding gas to approx. 2 thousand. rpm it seems to be much better.
    After a longer drive, the error "P0303" appears in the controller. Ignition failure cylinder no. 3.
    I replaced the coil for a replacement for PLN 250 and unfortunately it is still exactly the same.
    I changed the ignition wires and changed the candles, unfortunately without improvement. The error still appears, the car has no power and runs tragically at idle, the engine jerks and the exhaust is clearly heard that it does not run on all cylinders. The car has LPG, but the situation is identical with both fuels. Interestingly, removing the wires from the plugs one by one, you can feel a clear difference in work on each cylinder, so it looks as if it worked on everyone.
    Is it possible that in this case the driver is damaged, because, to be honest, I have no idea what to do with the car. Oh, and one more thing, at idle the ignition advance angle varies between 35-40 degrees, which in my opinion is very much too high.
  • #2 16679988
    ptr92
    Level 19  
    Help: 27
    Rate: 248
    The high voltage cables must not be removed from the spark plugs while the engine is running.
    And when did you change the oil in the engine?
  • #3 16680471
    osliczka
    Rate: 169
    And what does this have to do with it? About 6,000 ago
  • #4 16680993
    damdam
    Help: 274
    Rate: 950
    overhaul head, most likely HWDA or HWDB engine.
    ACME Damian Michalski
    Boczna 3a, Żory, 44-240 | Tel.: +48XXXXXXXXX (Show)
  • #5 16681064
    ptr92
    Level 19  
    Help: 27
    Rate: 248
    Read on
    https://www.elektroda.pl/rtvforum/topic3370532.html
  • #6 16681140
    grala1
    VAG group specialist
    Help: 1495
    Rate: 5052
    Start by adjusting the valves if there is no automatic adjustment.
  • #7 18149202
    Kuny
    Hello. Has the cause been established ?? I have a similar problem.
  • #8 18149311
    sebek3
    Level 30  
    Help: 125
    Rate: 343
    Check the ankle against the coil. Bend the pins in it. Often, it does not touch in these cars.
  • #9 18594961
    Kuny
    Hello. For me, valve adjustment helped. It was supported on the first cylinder, therefore an error appeared.
The discussion revolves around a 2007 Ford Focus II with a 1.6 petrol engine experiencing power loss and misfiring, particularly in cylinder number 3, indicated by error code "P0303". The owner has replaced the ignition coil, wires, and spark plugs without improvement. Responses suggest various troubleshooting steps, including checking the valve adjustment, inspecting the coil connection, and considering an overhaul of the engine head. Some users report similar issues and solutions, emphasizing the importance of proper electrical connections and valve adjustments.
