Blocked Vodafone 600 Phone: How to Bypass or Remove Google Account Lock After Reset
arteknowak13 10851 5
  • #1 16691864
    arteknowak13
    Hello ,
    I have a vodafone 600 phone, I made a reset and I can not get to it because the phone is swiped with a Google account, which I do not have access to.
    Does anyone of you know how to bypass or pass this blockade?
  • #2 16691907
    gruktel
    Level 32  
    Help: 200
    Rate: 309
    You must use a box that has to remove the frp block or go to the gsm command where this service will do it.
    GRUK Krystian Grudzień
    Chwałki 46, Sandomierz, 27-600
  • #3 20719325
    maxmaxy939
    Someone explain to everyone what the box is about
  • #4 20719385
    gracjan55
    Level 36  
    Help: 315
    Rate: 244
    It is a service device.
  • #5 20719435
    staś pytalski
    Help: 760
    Rate: 1438
    You can also try to look for a video on Youtube and some strange tricks to try to bypass the lock. Only not for every model of phone there is such a video, and also you need to try several tricks, from different videos, under the exact model and software version you have. It may also be that you will not succeed. Type in YouTube Vodafone 600 frp
  • #6 20720008
    winmap
    Help: 361
    Rate: 755
    I don't know what model you have but I'm shooting that this one.
    Try something from this To view the material on this forum you must be logged in. To view the material on this forum you must be logged in.
    Depends what kind of software you have as a colleague wrote above. It's best to look at the latest guides.
