[Solved] P9 Lite VNS-L21: Google Account Verification Issues, YT Unblocking, Emergency Calls & SIM Card
krecik10 9399 11
  • #1 17323470
    krecik10
    Rate: 56
    Please help what is wrong, that all information on YT lead to unblocking through the code entry in emergency calls with the sim card inserted, but the problem with me is that if I choose information about the phone and then abo1 as I have Polish language, or sub1 as English, then three dots in the upper right corner and select the first display the address book on the sim card, then when the circle turns it on all videos as they select the arrow in the upper left corner contacts are shown and for me returns to information about the phone.
  • #2 17323595
    nutergsm
    Help: 1034
    Rate: 1662
    Go to the site where they will remove frp blockage.
  • #3 17324120
    Ordine
    Help: 75
    Rate: 164
    Phone is not stolen?
    Check if "FRP Locked" is displayed in the fastboot.
  • #4 17325114
    krecik10
    Rate: 56
    Rather, the phone is not stolen (we can never be sure here) it is the daughter of a friend, "PHONE Locked" and "FRP Lock" are displayed in the fastboot.
  • #5 17325422
    Ordine
    Help: 75
    Rate: 164
    Only service, no boxes etc. etc. You won't do it at home. The phone has a fastboot blocked.
  • #6 17326491
    mamteflow
    Rate: 28
    You will do without box.ow see the way with talkback
  • #7 17326537
    krecik10
    Rate: 56
    The talkback method does not work either, i.e. after holding it down with two fingers the talkback suspended message is displayed.
  • #8 17326538
    Ordine
    Help: 75
    Rate: 164
    Will not go, talkback suspended will have.
  • #9 17326541
    krecik10
    Rate: 56
    You can ask for information what a good huawei box would be useful, i.e. flash, frp, simlock.
    kongomaj
    Help: 5
    Rate: 20
    For FRP, e.g. FastbootET01. One-time password needed, cost ~ 35 PLN.
    After the reset, the keys are also talkback suspended? It should start normally, then Talkback Settings> help and support or Privacy Policy> we are looking for Voice> we enter YouTube> 3 dots - Privacy Policy and we are in Chrome. It remains to download and install Google Account Manager and Quick Shortcut Maker and voila.
  • #11 17328178
    marcin7904
    Help: 138
    Rate: 257
    If you're not sure, don't mislead people because you write stupid things.
    Can be unlocked without a box and other programs.
    Just listen, read and watch with understanding.
  • #12 17328198
    krecik10
    Rate: 56
    Phone unlocked, thanks to a colleague kongomaj for targeting hard phone reset again, because I admit that I did not because the phone owner has already done it, after the talkback reset it works normally, the rest went without problem.
✨ The discussion revolves around issues related to Google Account verification on the Huawei P9 Lite VNS-L21, specifically regarding the inability to unblock YouTube through emergency call code entry with a SIM card inserted. Users suggest various methods to bypass the Factory Reset Protection (FRP) lock, including using a service for FRP removal, checking for "FRP Locked" status in fastboot, and utilizing the TalkBack feature. However, some users report that the TalkBack method does not work due to a suspension message. A successful solution involves performing a hard reset and using tools like Google Account Manager and Quick Shortcut Maker after resetting the device. The conversation highlights the challenges of unlocking the device without professional tools and the importance of following precise instructions.
TL;DR: If your Huawei P9 Lite VNS-L21 is stuck on Google verification, a fastboot FRP token costs ~35 PLN; "One-time password needed." Use the TalkBack-to-Chrome method or paid service to unlock and relink safely. This FAQ is for owners facing FRP, YouTube path, and emergency dialer code issues. [Elektroda, kongomaj, post #17328135]
Why it matters: It helps VNS-L21 owners fix FRP/Google verification, YouTube unblocking paths, and emergency-dialer SIM-contact issues fast.
How do I check if FRP is locked on my P9 Lite (VNS-L21)?
Enter fastboot and read the on-screen status line. “Check if ‘FRP Locked’ is displayed in the fastboot.” If it shows Locked, FRP is active. This quick check guides your next step, whether software bypass or service token. [Elektroda, Ordine, post #17324120]
Emergency dialer abo1/sub1 just returns to phone info—what should I do?
Skip the SIM-contacts exploit and try the TalkBack-to-Chrome method after a full factory reset. In this thread, the reset cleared issues and the TalkBack path worked, allowing the account step to complete. [Elektroda, krecik10, post #17328198]
TalkBack says “suspended.” How do I fix it to continue the FRP bypass?
Perform a full factory reset, then begin setup again. After the reset, TalkBack started normally for the OP, and the rest of the steps worked without trouble. Proceed to reach Chrome and install the needed APKs. [Elektroda, krecik10, post #17328198]
What’s the 3-step TalkBack-to-Chrome FRP method for VNS-L21?
  1. Enable TalkBack, open TalkBack Settings → Help & support or Privacy Policy.
  2. From Help, search “Voice” to launch YouTube; tap the three dots → Privacy Policy to open Chrome.
  3. Download and install Google Account Manager and QuickShortcutMaker; use it to add/sign in a Google account. [Elektroda, kongomaj, post #17328135]
I can’t find the three-dot menu in YouTube. How else can I reach Chrome?
From TalkBack Settings, use Help & support or the Privacy Policy link. Navigate to a page (e.g., Voice) that opens YouTube, then hit the three dots → Privacy Policy to jump into Chrome and continue. [Elektroda, kongomaj, post #17328135]
Can I unlock the P9 Lite without a box or special hardware?
Yes. Community members state it can be unlocked without a box by using the TalkBack path and APKs. “Can be unlocked without a box and other programs.” Follow the on-screen flow carefully for success. [Elektroda, marcin7904, post #17328178]
Fastboot shows “PHONE Locked” and “FRP Lock.” Can I do this at home?
With fastboot blocked, you cannot flash via fastboot at home. Some technicians insist on service tools in this state. “The phone has a fastboot blocked.” Consider a service token or shop if TalkBack fails. [Elektroda, Ordine, post #17325422]
How much does a paid FRP removal cost and what service is used?
Approx. 35 PLN for a one-time fastboot password using a service like FastbootET01. This token authorizes FRP removal when software routes fail. It’s a quick, paid alternative to TalkBack-based bypasses. [Elektroda, kongomaj, post #17328135]
Which apps do I need for the TalkBack method on VNS-L21?
Install Google Account Manager and QuickShortcutMaker after reaching Chrome. Use QuickShortcutMaker to open the right activity and add a Google account, completing the verification step. This combo was reported as working. [Elektroda, kongomaj, post #17328135]
After I reset the phone, TalkBack worked and I unlocked. Why did that help?
The fresh factory reset cleared the “suspended” state, allowing TalkBack to launch and the YouTube-to-Chrome route to succeed. After that, installing the APKs and adding an account finished the process smoothly. [Elektroda, krecik10, post #17328198]
How do I verify anti-theft status before trying anything?
Boot to fastboot and read the FRP line. “Check if ‘FRP Locked’ is displayed in the fastboot.” If it shows Locked, plan for an authorized account sign-in, TalkBack route, or service token. [Elektroda, Ordine, post #17324120]
What if TalkBack stays “suspended” even after a reset?
On some builds, the message persists and the TalkBack route will not proceed. “Will not go, talkback suspended will have.” In that case, consider a professional FRP service solution. [Elektroda, Ordine, post #17326538]
