Best Android Smartphone Under PLN 350: P8 Lite Alternatives & Durable Models with Good Camera
Raiz3n 3753 15
What durable Android smartphone with a decent camera can I buy for about PLN 350, and is there anything better than the Huawei P8 Lite at this price?
At about PLN 350, you should not expect to buy anything really good new, so used models are the more realistic option [#16705941] One concrete suggestion in this budget is the Lenovo C2 [#16706812] Another option worth considering is the BlackBerry Z30 rather than the Z10, because the Z10 has a weaker battery; the Z30 is said to have a decent camera, good physical durability, and generally solid behavior, though BlackBerry is a specific system and not the best choice if you want lots of apps or games [#16707398] BlackBerry 10 can handle some Android apps, and Google Play may be installable, but compatibility and battery life depend on the used unit’s wear [#16708146] If you still prefer the Huawei P8 Lite, one reply says it would be worth hunting for one with some warranty [#16706119]
  • #1 16705755
    Raiz3n
    Rate: 76
    I need a smartphone up to about PLN 350, I bought the Xperie Z1 compact, but this phone is a failure. The main camera took photos where nothing could be seen, lost range and broke off Wi-Fi. I am thinking about something with an android, that it would have a reasonably good camera, be quite durable and, above all, run smoothly. So far, I am most inclined to P8 Lite, I will find something better at this price? Shipping from China is dropping.
  • #2 16705840
    Szyszkownik Kilkujadek
    Level 37  
    Help: 211
    Rate: 1011
    Are you looking for new or used?
  • #3 16705903
    E8600
    Help: 529
    Rate: 2493
    Maybe another system?
  • #4 16705941
    qs300
    Help: 242
    Rate: 361
    In this money it's just a drug, you won't buy anything good from new ones.
  • #5 16706119
    Raiz3n
    Rate: 76
    Well, I am looking for stimulants, I bought this z1 compact like a new one from China and went a bit. Other systems are not, especially windows. I was in some lumia and a tragedy for me. p8 lite for this price even with some guarantee I would hunt.
  • #6 16706725
    qs300
    Help: 242
    Rate: 361
    I have Lumie 640XL, 5.7 ", Windows 10 Mobile and I will not exchange it for any Adnroid.
    Zero hang like on Adnek, no mussels, no shortage of memory, no clogging.
  • #7 16706812
    tino2003
    Admin of GSM Group
    Help: 1971
    Rate: 2085
    Raiz3n wrote:
    I bought this z1 compact like a new paper from China and got over it a bit
    This model is a fairly successful phone but, you bought junk after regeneration and that's why it behaves and not otherwise.
    In such a budget you can buy e.g. Lenovo C2.
  • #8 16706866
    kkknc
    Help: 1910
    Rate: 6660
    You can find something interesting at the kitajca from new ones.
  • #9 16706878
    tino2003
    Admin of GSM Group
    Help: 1971
    Rate: 2085
    He has already found one, do you want to recommend another? :D
  • #10 16707063
    E8600
    Help: 529
    Rate: 2493
    For me, the only Windows on the phone is old 6.5 new have too many restrictions. As for another system, I would recommend BlackBerry OS 10 the best system - I have one and I will not change my Z30 quickly.
    With Android there are always some bigger or smaller problems regardless of the phone, the sister has S7 and complains about liquidity and the only advantage of this phone is the camera, I think.
  • #11 16707282
    Raiz3n
    Rate: 76
    I reviewed the allegro, from tactile BlackBerry in this money I would like z10 or z30, they are available with a 30 day service warranty. So probably repaired and released, I'm a bit afraid to buy such a phone but maybe I would decide. When it comes to Chinese people, it doesn't come into play, I've already burned.
  • #12 16707290
    qs300
    Help: 242
    Rate: 361
    In Windows 10 Mobile, there are no such restrictions as in older versions.
  • #13 16707398
    E8600
    Help: 529
    Rate: 2493
    Please think seriously because if you are a fan of android and lots of applications / games then I advise against BlackBerry despite the fact that it copes with most applications for anroid. The camera may not be top-flight, but I think the pictures are correct. Of those you mentioned, only z30 because z10 have a weaker battery. Look for tests of this system on the network and decide for yourself because one suits others is missing an android. These phones are not very popular so it is difficult to buy and in addition I can see that they have become more expensive recently probably because there are less and less of them on the secondary market.
    People who have had contact with this phone are buying a new one in 2017 despite the passage of years link .
    I do not want to convince you also consider this Windows what a colleague suggests.
  • #14 16707829
    Raiz3n
    Rate: 76
    No, I'm not a fan of android, it just seemed to me always more intuitive and generally easier system than windows. Version 8.1 windows alienated me so much that I look at every other through the prism of it, I watched the review of windows 10 and BB 10, the BB product seems to me similar to android in some matters. I read about it z30 and quite ok only some mentioned problems with texting. I write sms on the phone and sometimes ring. He works physically and the phone will often fly to earth, in this respect the z30 has very good reviews. Rather, I do not use any applications, sometimes navigation, not the best reviews about it, but there are probably some alternative applications.
  • #15 16708146
    E8600
    Help: 529
    Rate: 2493
    Sms, you have to learn gestures and then you write the first SMS quickly, I couldn't write either. I don't know with navigation because I don't use it, but I heard that you can install the Google store and then the one from android works. As for the battery, one lasts a day and the other a few depends on luck how worn you hit. In 2 days I will not be able to torment and usually I have 4 days. I do not want to persuade because BlackBerry is specific but it's best if you had a friend with this system to test. BlackBerry has an Android 4.2 emulator, which is why some android applications work on it.
  • #16 17194547
    Raiz3n
    Rate: 76
    I close some topics. Generally, the seller made me a horse when I sent the phone back, the case went to the police and I got a refund from the buyer protection program, I was struggling for over 8 months. Eventually I bought xiaomi redmi 4a 16gb, after less than 2 months I'm happy. Pozdraiwam
✨ The discussion revolves around finding a durable Android smartphone under PLN 350, with a focus on alternatives to the P8 Lite and a good camera. The user expresses dissatisfaction with the Xperia Z1 Compact due to poor camera performance and connectivity issues. Responses suggest considering various options, including the Lenovo C2 and Xiaomi Redmi 4A, which the user ultimately purchased and is satisfied with. There are also mentions of BlackBerry devices, specifically the Z10 and Z30, but concerns about their app ecosystem and usability are raised. The conversation highlights the challenges of finding quality smartphones in a low budget and the importance of warranty and reliability.
TL;DR: Under PLN 350, expect used/refurb options; one BB10 user reports "you have to learn gestures" and gets up to 4 days battery. Prioritize smooth performance, basic camera, and safe buying with protection programs. [Elektroda, E8600, post #16708146]
Why it matters: This FAQ helps bargain hunters compare P8 Lite alternatives and durable phones with decent cameras—without getting burned.
Is Huawei P8 Lite the best Android under PLN 350?
It’s a common shortlist choice at this price, especially when buyers want Android, a usable camera, and smooth basics. If you pick it, verify condition, IMEI, and any remaining warranty. Avoid listings that look like “regenerated” stock sold as new. Prioritize seller reputation and a return window. [Elektroda, Raiz3n, post #16705755]
New or used—whats realistic for PLN 350?
Expect used or refurbished. Community consensus here was blunt: from new stock at PLN 350, quality will be limited. Used devices with verifiable history and warranty outperform brand‑new, ultra‑budget picks at this level. “Good from new ones” at this price was called unrealistic. [Elektroda, qs300, post #16705941]
What are solid alternatives to the P8 Lite in this range?
Consider Lenovo C2 for basic Android duties. It was suggested as a workable budget pick if you want a straightforward device. Confirm battery health and screen integrity, since replacements can erase any initial savings. Load only essential apps to keep it responsive. [Elektroda, tino2003, post #16706812]
Is Xiaomi Redmi 4A a safe choice under PLN 350?
Yes, one buyer here ended up with a Redmi 4A 16 GB and reported satisfaction after less than two months. Ensure you get a clean software build and verify the IMEI before first boot. Keep storage usage lean to maintain smooth operation. [Elektroda, Raiz3n, post #17194547]
Why did my Xperia Z1 Compact have awful camera and Wi‑Fi drops?
Likely a refurbished unit sold as “new.” A respondent flagged such Z1 Compact issues as typical of “junk after regeneration.” Refurb processes can mask water damage or poor module swaps, causing camera noise and unstable radios. Return or claim protection if symptoms match. [Elektroda, tino2003, post #16706812]
Will Windows 10 Mobile run smoothly at this budget?
If you can accept Windows 10 Mobile, reported performance was very smooth on Lumia 640 XL. One user said, “Zero hang… no shortage of memory.” App selection is limited, but core calling, texting, email, and photos work reliably. [Elektroda, qs300, post #16706725]
What is BlackBerry 10 (BB10), and can it run Android apps?
BB10 is BlackBerry’s OS with gesture navigation and a productivity focus. It includes an Android 4.2 runtime, so some Android apps can run after adding the store, but compatibility varies. “You have to learn gestures,” yet many users adapt quickly. [Elektroda, E8600, post #16708146]
How durable is the BlackBerry Z30 for field work?
The Z30 was praised by a user who works physically; it handled frequent drops well. If durability matters more than app breadth, it’s a pragmatic pick. Add a grippy case and tempered glass to cut repair risks further. [Elektroda, Raiz3n, post #16707829]
How good is the BlackBerry Z30s camera?
Expect “correct” photos rather than flagship results. A user contrasted it as not top‑flight but acceptable for everyday shots. Keep HDR off in low light to reduce blur, and tap‑to‑focus for sharper frames. [Elektroda, E8600, post #16707398]
What warranty is typical for refurbished Z10/Z30 units?
Listings frequently include a 30‑day service warranty. Treat that as minimal coverage and test everything in week one: cameras, Wi‑Fi, LTE, GPS, speaker, and battery endurance. Document defects immediately for returns. [Elektroda, Raiz3n, post #16707282]
Should I buy from China sellers to hit this price?
Proceed with caution. The OP reported getting burned and now avoids such listings. If you do risk it, insist on buyer protection and local return options. Factor long shipping and potential customs into total cost. [Elektroda, Raiz3n, post #16707282]
How do I avoid getting a bad refurb? (3‑step checklist)
  1. Buy with platform protection; one refund took over 8 months, so document everything.
  2. Inspect on arrival: run camera, Wi‑Fi, Bluetooth, GPS, and a battery drain test in 72 hours.
  3. Check IMEI/serial against box and invoice; reject mismatches immediately. [Elektroda, Raiz3n, post #17194547]
Can I add Google Play for navigation on BB10?
Yes, users report installing the Google store and running some Android navigation apps on BB10’s Android 4.2 runtime. Compatibility is hit‑or‑miss, so test your preferred app early and keep an offline map fallback. [Elektroda, E8600, post #16708146]
What does “after regeneration” mean in listings?
It usually means refurbished: parts swapped, software reflashed, and cosmetic fixes applied. One expert comment warned such units can behave poorly if corners were cut. Avoid “like new” claims without service paperwork. [Elektroda, tino2003, post #16706812]
Is Windows 10 Mobile less restricted than older Windows Phone versions?
Yes. A participant noted Windows 10 Mobile removed several limitations present in older versions. If you disliked Windows Phone 8.1, try 10 Mobile before deciding; basics and settings are more flexible. [Elektroda, qs300, post #16707290]
If camera quality matters most at PLN 350, what should I expect?
Aim for “usable” rather than “great.” The thread’s Android picks target smooth use and durability, while BB10 users accept “correct” images. For better low light, reserve budget for a case and buy a device in top condition. [Elektroda, E8600, post #16707398]
