Troubleshooting Broken Headphone Jack on Huawei P9 Lite: One-sided Audio Issue
Wiciu400v 6924 2
  • #1 16716608
    Wiciu400v
    Rate: 33
    Yesterday, wanting to listen to music, I encountered a problem, namely after connecting the headphones and selecting a song, this problem appeared one of the headphones did not work, at first I thought that the problem lies with the headphones because I have them for some time and you know they could go wrong, but after you arrive home I took new headphones and connected thinking that the problem lies with the headphones I tried with five other headsets and the same each time. This morning I saw something interesting, pushing the plug from the side, the headphones began to work normally and when I let go they stopped. What could happen? I am asking for a quick answer, maybe someone has already met it.
    If it is important, the right handset has not always worked.
    KRY5PIN
    Level 37  
    Help: 312
    Rate: 467
    There are two options. Either the HF socket is dirty or the socket has already received moisture. There are two solutions, either you add a phone to the service, or you can cut it out and clean it yourself.
  • #3 16716841
    Wiciu400v
    Rate: 33
    I don't know if it is dirty ... how to check it and how to clean it ??? The second option is more likely it rains a lot lately and the phone itself was not flooded but the humidity was quite large and I walked with it in a soaked jacket ... what to do to fix it (I would prefer not to return the phone to the service because once on the phone I have a lot of private and needed things and two I travel 16km every day and somehow go without a phone is a bit hard not from the point of entertainment or something but God forbid something will happen and even for help I won't call [I don't have a second phone]) service treats options finality.
