Huawei P8 Lite ALE-21: Headphones Always Connected Issue, Socket Replacement & EMUI 4.0.3
brzozu 8649 2
  • #1 17064145
    brzozu
    As in the subject Huawei P8 Lite ALE-21 Android 6.0 / EMUI 4.0.3
    The problem is that the phone always shows the headphones connected. Socket replacement, software update, factory reset did nothing. After the mentioned disadvantage, the phone is "fully" functional. I know that there is an application that allows you to switch between headphones and speaker, but it is quite tedious in everyday use.
    I am afraid that something from the general cargo near the nest is compact and causes such behavior. Maybe one of the forum users encountered a similar defect? Below is a diagram of general cargo and headphone jack
    Thank you for your interest and best regards,
    Paul
    • headphone.pdf (220.59 KB) You must be logged in to download this attachment.
  • #3 17074217
    brzozu
    Thanks for the quick and accurate diagnosis, after replacing the system everything returned to normal.
