Transistors Explained: Unipolar/Bipolar, PNP/NPN Keys, Differences & Uses for Beginners
Paweni 9819 9
How do bipolar and unipolar transistors differ, what is the difference between NPN and PNP transistors, and what are transistors used for?
Bipolar transistors are controlled by current, while unipolar transistors are controlled by voltage; the bipolar type has base, collector, and emitter, and the unipolar type has gate, drain, and source [#16755522] NPN and PNP are opposite in operation: an NPN transistor is driven by a positive base voltage relative to the emitter and current flows from collector to emitter, while a PNP transistor works the other way around with current flowing from emitter to collector and a negative base voltage [#16755522] Transistors are used mainly as signal amplifiers and as switching/control elements in circuits [#16755522] For a beginner, it was recommended to start with bipolar transistors first and then move on to unipolar ones [#16755849] In practice, transistors are used everywhere in electronic circuits, from simple switching tasks to more complex signal processing [#16755522]
  • #1 16755469
    Paweni
    I am a beginner electronics and I started with the subject of transistors,
    so I have some questions:
    -What is the unipolar transistor for?
    -What is the bipolar transistor for?
    -What is the difference between a bipolar and unipolar transistor
    -What is the difference between a PNP Key and an NPN Key
    -What are the uses of transistors
    I was looking for answers on Google, but as I mentioned, I'm a beginner
    an electronics engineer and as I looked on the internet it is too "advanced language" for me
  • #3 16755522
    MiernikZKauflanda
    Help: 29
    Rate: 60
    Question 1 and 2
    All transistors are important parts of more or less complex circuits (integrated and "unscaled") - they make for signal amplifying and signal controlling elements. However, please note that the transistor itself is only a transistor - only after attaching elements (resistors, capacitors, other transistors, etc.) can we talk about an amplifier.
    Question 3
    The most important difference between a bipolar and unipolar transistor is that the bipolar transistor is controlled current , i.e. the gain depends on the current strength based on the transistor, and the unipolar transistor is controlled voltage , i.e. the gain depends on the voltage at the gate. You can immediately indicate another difference - in the naming of electrodes (i.e. leads, do not confuse with our forum :D ). The bipolar transistor has base, collector and emitter while the unipolar transistor has respectively: goal, drain and source . There is also a difference in the construction and use in systems.
    Question 4
    The difference between the NPN and PNP key is that the NPN key is controlled by positive voltage on the base (relative to the emitter) and the current flows from the collector to the emitter, whereas in the case of the PNP key it is exactly the opposite: the current flows from the emitter to the collector and the key is controlled by a negative base voltage.
    Question 5
    Transistors are basically used everywhere - they are irreplaceable and it's hard to do something without them (at most the so-called "crystal radio"). Of course there are also electron tubes that used to "do" transistors, but today they are no longer used, with the exception of tube radios (in the event of an atomic war, read yourself), tube hi-end amplifiers and systems made by "tube fans" or amateurs who they make retro layouts from the last century.
  • #4 16755607
    Paweni
    Thank you very much for the comprehensive answer, but I have one more question:
    How to control voltage and current.
  • #5 16755778
    QarWave
    It is not "voltage and current control", but voltage and current control, to do this you must know the basic laws and have basic knowledge. You have to read a lot about it and get to some things yourself, not just ask in the forum "how? What for? And why?" because you will still not understand.
    https://www.elektroda.pl/rtvforum/topic1726169.html
    I recommend exploring and doing something of what they recommend there, you will certainly light up a lot of things, and if you do not know something, search first, then ask.
  • #6 16755849
    MiernikZKauflanda
    Help: 29
    Rate: 60
    Describe in your own words what you mean by current and voltage control. The transistor can be operated, but not the voltage / current!
    In my speech, the point was that in circuits based on bipolar transistors the signal gain depends on current flowing from the base to the emitter . However, in systems with unipolar transistors the gain depends on voltage between gate and source . Do you see the difference?
    Since you are a beginner, for now take care only of bipolar transistors, when you master them then get yourself unipolar.
    Each bipolar transistor has a parameter called hFE (or ? ;) in other words - strengthening. If we lead to a situation (i.e. we build a suitable system) that 10mA will flow from the base to the emitter when hFE = 200, then the current flowing from the collector to the emitter is Ibe * hFE (base-emitter current * gain), i.e. in this case 2000mA, i.e. 2A. It is worth noting that not every transistor will withstand such current, and each transistor has a different hFE, but the average values are given in the catalog cards, which are taken in the calculations.
    I know it can be gibberish for you :D so read something that colleagues said. I recommend the Electronics Course from myself at forbot.pl, everything is nicely explained there.
    https://forbot.pl/blog/kurs-elektroniki-tranzystory-bipolarne-w-praktyce-id4315
    and here the link from the beginning of the course:
    https://forbot.pl/blog/kurs-elektroniki-napiecie-prad-opor-zasilanie-id3947
  • #7 16756153
    themosfet124
    Help: 30
    Rate: 81
    MiernikZKauflanda wrote:
    In my speech, the point was that in circuits based on bipolar transistors the signal gain depends on current flowing from the base to the emitter . However, in systems with unipolar transistors the gain depends on tensions between the base and the emitter .Do you see the difference?
    And since when do we have Base and Emitter in unipolar transistors ?? :D
  • #8 16756181
    jarek_lnx
    Help: 4198
    Rate: 6126
    2000mA or 1A
    Interesting...
  • #9 16756326
    MiernikZKauflanda
    Help: 29
    Rate: 60
    Sorry for stupid mistakes, I wrote at night, I have already corrected.
  • #10 16764532
    Paweni
    Thank you very much for the extensive answers, but the best explanation I found on YouTube, on the RS Electronics channel.
    I understood that the transistor is used to turn on e.g. light bulbs, but not high voltage like 230V, only e.g. 1V,
    so I already know what the transistor is for and I can close the topic
Transistors are essential components in electronic circuits, functioning primarily as signal amplifiers and controllers. There are two main types of transistors: unipolar and bipolar. Unipolar transistors are voltage-controlled devices, while bipolar transistors are current-controlled. The key difference between PNP and NPN bipolar transistors lies in their current flow direction and configuration. Beginners are advised to focus on understanding bipolar transistors first, as they are foundational in electronics. Practical applications of transistors include switching and amplifying signals, such as controlling low-voltage devices like light bulbs. Resources for further learning include online PDFs and video tutorials.
