How to Remove Pop-up Ads on OLX: Tried Cleaner and Malwarebytes with No Success? Use Adblock!
radifumi 13017 6
  • #1 16767127
    radifumi
    Rate: 28
    How to remove pop-up ads on olx. I cleaned with clener, malwarebytes, but it did nothing. I have Adblock attached.
  • #2 16767156
    qwertexx
    Help: 11
    Rate: 44
    Go to programs and functions / uninstall programs (depending on the system) and see if you have any strange programs that you did not install, if you have, uninstall them.
  • #3 16767157
    Kolobos
    IT specialist
    Help: 17172
    Rate: 10457
    Include in the attachment the required logs from FRST, that scan!
  • #4 16767668
    radifumi
    Rate: 28
    Here are the required logs:
    • Shortcut.txt (50.14 KB) You must be logged in to download this attachment.
    • Addition.txt (34.66 KB) You must be logged in to download this attachment.
    • FRST.txt (23.65 KB) You must be logged in to download this attachment.
  • FRST fixlist removes McAfee Security Scan Plus and Pokki
    #5 16767776
    krzychupar
    Help: 1490
    Rate: 633
    Odinstaluj:
    Otwórz notatnik systemowy i wklej:
    ShellIconOverlayIdentifiers: [00asw] -> {472083B0-C522-11CF-8763-00608CC02F24} => -> Brak pliku
    ShellIconOverlayIdentifiers: [00avast] -> {472083B0-C522-11CF-8763-00608CC02F24} => -> Brak pliku
    ContextMenuHandlers5: [igfxcui] -> {3AB1675A-CCFF-11D2-8B20-00A0C93CB1F4} => -> Brak pliku
    Task: {E1FC8CAF-7B7E-4B7E-A3FD-EDF0D5E8FF7F} - System32\Tasks\Pokki => C:\Users\Lenovo\AppData\Local\Pokki\Engine\HostAppServiceUpdater.exe
    Startup: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup\McAfee Security Scan Plus.lnk [2017-09-29]
    ShortcutTarget: McAfee Security Scan Plus.lnk -> C:\Program Files\McAfee Security Scan\3.11.599\SSScheduler.exe (McAfee, Inc.)
    GroupPolicy: Ograniczenia - Chrome DefaultScope {0633EE93-D776-472f-A0FF-E1416B8B2E3A} URL =
    SearchScopes: HKU\S-1-5-20 -> DefaultScope {0633EE93-D776-472f-A0FF-E1416B8B2E3A} URL =
    SearchScopes: HKU\S-1-5-21-316054017-2341695211-2374014760-1001 -> {3EFDEE8D-F7B1-468C-9F48-FFB2791922DC} URL =
    CHR HKLM-x32\...\Chrome\Extension: [efaidnbmnnnibpcajpcglclefindmkaj] - hxxps://clients2.google.com/service/update2/crx
    CHR HKLM-x32\...\Chrome\Extension: [lifbcibllhkdhoafpjfnlhfpfgnpldfl] - hxxps://clients2.google.com/service/update2/crx
    S3 McComponentHostService; C:\Program Files\McAfee Security Scan\3.11.599\McCHSvc.exe [404376 2017-09-05] (McAfee, Inc.)
    S3 hwdatacard; \SystemRoot\system32\DRIVERS\ewusbmdm.sys [X]
    2017-09-29 21:37 - 2017-09-29 21:37 - 000000000 ____D C:\ProgramData\Microsoft\Windows\Start Menu\Programs\McAfee Security Scan Plus
    2017-09-29 21:36 - 2017-09-29 21:36 - 000000000 ____D C:\ProgramData\McAfee Security Scan
    2017-09-29 21:37 - 2017-06-30 12:07 - 000001991 _____ C:\Users\Public\Desktop\McAfee Security Scan Plus.lnk
    2017-09-29 21:37 - 2017-06-18 09:13 - 000000000 ____D C:\Program Files\McAfee Security Scan
    EmptyTemp:
    Plik zapisz pod nazwą fixlist.txt i umieść obok FRST w tym samym folderze.
    Uruchom FRST i kliknij w Fix/Napraw.
  • #6 16768010
    radifumi
    Rate: 28
    Save this text as a fixlist and paste into this second folder I understood correctly? Then open the program and fix it, yes I did, but ads keep popping up.
  • #7 16768019
    Kolobos
    IT specialist
    Help: 17172
    Rate: 10457
    There are normal ads on OLX and it has nothing to do with this department. You don't want ads, then install e.g. uBlock Origin.
The discussion revolves around the persistent issue of pop-up ads on OLX, despite attempts to remove them using Cleaner and Malwarebytes, as well as having Adblock installed. Users suggest providing logs from FRST for further analysis and recommend uninstalling McAfee Security Scan Plus, which may be contributing to the problem. Another user advises that OLX contains normal ads, and suggests using uBlock Origin as an alternative ad-blocking solution.
