Tantalum Capacitor Polarity: Identifying Plus(+) Leg - Shorter or Longer? Capacity & Voltage
szczukot 13266 5
  • #1 16798199
    szczukot
    Help: 6
    Rate: 83
    I have a tantalum capacitor (not SMD) without any strip, etc. There are only indications of capacity and voltage.
    Which leg is a plus (shorter or longer)?
    Phantom
  • #2 16798209
    szkieletor11111
    Help: 63
    Rate: 149
    I would take a picture and put it in the post.
  • #3 16798212
    icosie
    Help: 298
    Rate: 239
    Plus is usually on a longer leg or where there is a line (tantalum capacitors). Sometimes there are also +/- markings next to the pins.
    edit: A photo would make sense, because it may not be tantalum, only polyester or ceramics.
  • #4 16798263
    szczukot
    Help: 6
    Rate: 83
    It looks like these: Tantalum Capacitor Polarity: Identifying Plus(+) Leg - Shorter or Longer? Capacity & Voltage
    Only different voltage and capacity.
    Phantom
  • #5 16798271
    icosie
    Help: 298
    Rate: 239
    You can clearly see the plus size around 35, this foot is a "plus"
    edit: the plus leg is also longer in the picture
  • #6 16798276
    szczukot
    Help: 6
    Rate: 83
    Thanks a lot. I thought it was just a voltage indication (yes I above capacity).
    Phantom
