Identifying Plus & Minus on 12V Power Supply with Torn Terminals Using a Meter
131165 16
How can I identify which wire on a 12V power supply is positive and which is negative using a meter?
Set your multimeter to DC volts and measure across the two output wires: if the display shows a positive value like 12.0 V, the red probe is on + and the black probe is on -, and if it shows a minus sign, the probes are reversed [#5992686] If the supply has an output electrolytic capacitor, its marked (-) side can help you trace which wire is negative [#5992747] If the wires are both black, a white stripe is often used to indicate the + lead, though you should verify it with the meter [#5993017] You can also compare the unknown supply to a battery with known polarity: connect the meter to the battery first, then to the supply, and the same sign means the leads are the same way round [#15268813]
  • #1 5992657
  • #2 5992686
    niutat
    Level 36  
    Help: 288
    Rate: 758
    Hello, if you have a digital meter and it will show you, for example, 12.0V, then you have (+) on the red wire, and if -12.0V (a dash before the value), it will be (-) on the red wire.
  • #3 5992731
  • #4 5992747
    niutat
    Level 36  
    Help: 288
    Rate: 758
    I meant the wires to the meter, you can still check the electrolytic capacitor at the output of the power supply will be marked (-) on it, check which wire is connected to it.
  • #5 5992753
  • #6 5993010
    Elmont
    Help: 68
    Rate: 220
    Buddy, lead the wires outside the power supply and bring them to
    the cut potato. There will be an environment on the positive pole / + /
    the tips on the potato are red, the negative pole / - / will be
    the potato was dyed blue. Note!. Be careful only
    low voltage on the secondary side of your power supply You can check this.
  • #7 5993017
    Yasiek_N
    Help: 6
    Rate: 9
    dadurec wrote:
    so that both wires in the power supply are black, including 1 with a white stripe along the length. Could you please explain to me how for "total crowd" ?? ;] because I don't know much about electronics.
    The statement of my colleague is very vague. I assume the wire with the white stripe is plugged into the (+) jack. Black - to the (-) slot. You connect the meter. On digital - the previous speaker has already explained to you. On analog - if the (+) from the power supply is on the (+) of the meter, you will measure the voltage. If the (-) of the power supply is on the (+) meter, the pointer will move to the left. If the operation of the meter scares you, take a clear, clear photo and post it on the forum (according to the rules!).
  • Electrolysis and potato tests for identifying power polarity
    #8 13727779
    nemoein
    Rate: 14
    I know the golden shovel is waiting, but this is the highest positioned answer in google :) I will skip having an ammeter or even any receiver compatible with the power supply specification, let's assume that we do not know which cable is plus and which is minus, and we are total laymen in the world of electricity. There are 2 simple methods for this:
    1. Electrolysis: Put 2 cables into slightly salted water, turn on the electricity, from the one where bubbles will be emitted is a minus, if nothing appears on any of them, wrap the cables around a screw or something metal to increase the surface and similarly - bubbles = minus, none = plus.
    2. Potato: Cut a potato in half, stick the cables into the potato, turn on, after a few minutes there will be a blue coating on the minus side, and red on the plus side.
    I do not need to explain so as not to connect the wires, not to use high voltage current, the intensity is not of particular importance because the receiver will not take more than it needs :) greetings
  • #9 13727827
    krakarak
    Help: 681
    Rate: 1846
    The theme and level are suitable for the HydePark department :D . The author has a meter and you advise him to measure the polarity with potatoes and electrolysis. Just advise what to solder the plug to these wires without a soldering iron, there will be a set.
  • #10 13727842
    olekt2002
    Level 32  
    Help: 147
    Rate: 515
    Not even there, but straight to the Trash. I do not believe that in Inowrocław the author would not find someone who can use a multimeter. Such an inquiry on Elektroda should immediately land in the Trash.
  • #11 15268813
    smola76
    Rate: 13
    Explanation from Lajkonik for Lajkonik?
    Assumptions: I have a meter, but I still don't know what or how. ?
    I took a battery (it has polarity markings) and connected the battery: I know where the plus and minus are (from the battery). I also know what the meter shows. I connect the meter to the tested voltage source, just like a battery. The meter indication as for the battery (i.e. only + or -) means that the cables are like in the battery, and the opposite sign - the opposite.
    By the way, you will also deal with the markings on the meter.
  • Using a battery to verify meter polarity readings
    #12 19346643
    harnas2
    And if, when I connect the battery, one side and the other and the meter shows me the same thing every time? What am I doing wrong??
  • #13 19347196
    398216 Usunięty
    Help: 3925
    Rate: 9448
    A minus should appear (when polarity reversal) before indicating the absolute value in V.
  • #14 19347204
    smola76
    Rate: 13
    Hmmm,
    you do not measure the voltage but a different value available on the multimeter? The voltage is usually marked with V. A R6 battery (finger) should give results in the vicinity of + or - 1.5V (depending on the state of discharge).
    Maybe you are connecting something wrong when the meter has more than two sockets.
  • #15 19347696
    krakarak
    Help: 681
    Rate: 1846
    harnas2 wrote:
    And if how I connect the battery one page and the other and every time the meter shows me the same ?? What am I doing wrong??
    What are you doing wrong You're having a lot of fun because it's just plain clown without panache.
    He makes a joke out of you and you write philosophical essays without reading and thinking ...
  • Using motor rotation to identify battery polarity
    #16 20647500
    123dawid13
    I can't comment because I'm not an expert. Recent statements here on the forum negate the point of asking about such grounds. And the most important thing is to start doing something and do it well. Now via Google I found this discussion because I have an old drill/driver from 18 years ago and I bought a battery from a modern Li-ion screwdriver, but there is no plus and minus marked on it. I'm not sure if the connection will be like in the other one, or maybe vice versa. This is where I looked. In other cases, it is also important, when the cables coming out of the battery are not marked, electronics here. Then I connect a battery with marked poles to the motor and look in which direction the rotor turns, and then I connect a battery without markings and also look in which direction the rotor turns. If the same, then the wires set have the same poles as on the known battery. It is the answers, reasonable, simple to such questions, that are most important for those who start doing something.
  • #17 20647751
    398216 Usunięty
    Help: 3925
    Rate: 9448
    123dawid13 wrote:
    and then I connect a battery with marked poles to the motor and look in which direction the rotor turns, and then I connect a battery without markings and also look in which direction the rotor turns.
    And how can you be sure which direction the motor should rotate at a given polarity of the power supply?
The discussion revolves around identifying the positive and negative terminals of a 12V power supply with torn terminals using a multimeter. Users suggest various methods to determine polarity, including using a digital multimeter to measure voltage (where a positive reading indicates the red lead is on the positive terminal), checking electrolytic capacitors for markings, and employing unconventional methods like electrolysis or using a potato to observe color changes. Some participants emphasize the importance of understanding multimeter usage and suggest connecting known batteries to verify polarity. The conversation also touches on the need for caution when working with electrical components and the significance of proper connections.
