Wordpress - The uploaded file could not be moved to wp-content / uploads
bocher 6090 4
  • #1 16813442
    bocher
    Hello, I included the problem in the topic that I previously searched in google and changed the permissions of the uploads folder to 777 but it did not give any result. Maybe I'm doing something wrong but the settings are on 777 and the problem is still there.
    best regards
  • #2 16813828
  • #3 17047699
    Czytlenik
    You have the message that it cannot be moved - that is, the problem can also be at the source - i.e. in the temporary folder - maybe this file is simply not there?
  • #4 17047850
    Czytlenik
    Check if there are files in the temporary folder, what permissions they have, if the user group (or the user himself) from the server matches the one in the target folder.
  • #5 17049380
    et-cetera
    I had the same problem 3 days ago after updating WordPress
    first, check if the amount of space on the server has run out, because I had over 2 GB of temporary files during the installation
    after cleaning the files the problem still appeared, but sometimes the file could not be sent
    I have reinstalled WordPress and everything works so far
