Win 7 - Change / delete Admin password in Admin Account in Win 7
BlackMaska 6603 6
  • #1 16827524
    BlackMaska
    This is a rather unusual matter so I will start from the beginning.
    Long ago, I set up a password for Admi than e to protect your computer against attempts to view your files from outside.
    That i am fucking I set up auto login so you don't have to enter the password every time you start your PC.
    But after a long time I forgot my password and I can't remember.
    Can you somehow remove / change the admin password having access to the admin without knowing the password?
    Moderated By RADU23:
    Please, don't use profanity.
  • #3 16827614
    BlackMaska
    Having access to the admin can't change / remove the password without external programs?
    Here it is that the password only blocks me from accepting files from the LAN and does not interfere with everyday use because the computer logs in automatically.
    Is there a registry that has this password?
  • #4 16827624
    Kolobos
    IT specialist
    Help: 17171
    Rate: 10456
    In the "user accounts" control panel you have the option to change your password.
  • #5 16827634
    BlackMaska
    Requires you to enter your current password.
  • #6 16827637
    Kolobos
    IT specialist
    Help: 17171
    Rate: 10456
    That's why I gave you a link to the password reset program.
  • #7 16827659
    BlackMaska
    I have repaired it in a different way ...
    I got into Computer Management and made an admin account without a password, then logged into it and removed the password from the old account.
The discussion revolves around the challenge of changing or removing an admin password in Windows 7 when the user has forgotten it. The user initially set up a password for security but enabled auto-login, leading to the current issue of password retrieval. Responses suggest using external tools like NT Password to reset the password, as the built-in "User Accounts" control panel requires the current password for changes. One user successfully created a new admin account without a password through Computer Management, allowing them to remove the password from the original account.
