Best Current to Charge 4 Laptop Batteries (3.7V, 2200mAh) in Series: General Formula
Brentlok 8400 10
How do I charge four 3.7 V, 2200 mAh laptop Li-ion cells connected in series, and is there a general formula for the charging current and time?
For four 3.7 V, 2200 mAh Li-ion cells in series, use a proper 4S Li-ion charger/balancer and not a simple fixed-voltage supply; a full 4S pack charges to 16.8 V, and series cells should be balanced with protection (PCM) [#16841526] The usual current guideline given is about 1C, so for 2200 mAh cells that is about 2.2 A maximum, though lower values like 2.0 A or 1.8 A are gentler on the pack [#16839620][#16841526] One reply also gave the charging-time estimate as T = 1.4 × C / I, with C in mAh and I in mA, which you can use for a rough charge-time calculation [#16839643]
  • #1 16839560
    Brentlok
    I have 4 batteries from a laptop battery each with a voltage of 3.7v and a capacity of 2200 mAh if I connect them together they will give ~ 14.8V current, so my question what current should I charge? Is there a general formula and how is it?
  • #2 16839620
    icosie
    Help: 298
    Rate: 239
    lalu931 wrote:
    In this case, 1C current is 2200mah = 2.2A maximum, but it is not recommended to charge with maximum current, for a healthier package it will be less, e.g. 2 A, 1.8A, so that it will last longer for you to charge
    No 1C current is a murder for rechargeable batteries, especially without temperature control !!
    It is recommended to charge with 0.1C current with a voltage slightly higher than the whole package. In this case, approx. 15V
  • #4 16839635
    Brentlok
    Ok thank you very much for your help :)
    PS And is there a pattern for loading?
    icosie
    Help: 298
    Rate: 239
    Brentlok wrote:
    Is there a pattern for loading?
    T = 1.4 x C / I
    T - charging time (h)
    C - battery capacity (mAh)
    I - charger charging current (mA)
    You can slightly extend the time by rounding it up to a full hour.
    krzysiek_krm
    Level 40  
    Help: 716
    Rate: 599
    your description shows that these are probably lithium-ion cells. It is advisable to charge them using a specialized system that implements the appropriate charging characteristics. If there are any markings on these links (manufacturer, model, etc.) try to look for documentation, the manufacturer knows the parameters of his products best. In general, however, lithium-ion cells can be charged with a current of 1C, in the CC phase, of course.
    If they are actually li-ion cells, then theorem
    is (without offense) complete nonsense.
    First of all, would you buy a laptop in which the battery charges for several hours?
    Secondly, 3.7V is certain conventional nominal voltage lithium-ion cell. In fact, the voltage varies from about 2.8 V to about 4.2 V. A fully charged 4S battery will have a voltage of 16.8 V, I wonder how you want to charge it with 15 V, probably through the fourth dimension.
    To sum up, use a specialized charger to charge the li-ion cells. You can charge with a current of about 1C, but it's better to check the documentation if it is possible. If the cells are connected in series, it is advisable to balance them. In addition, you should strongly recommend the use of the "secondary protection" system, which is the "last line of defense" for cells when other systems are damaged. You can remove this system from the battery from which you get the cells, or buy, commercially these systems are called "PCM", the prices are rather low. You need to purchase a chip for your cell configuration, for example 4S.
    Regards
    szkieletor11111
    Help: 63
    Rate: 149
    It's exactly like a colleague writes in the previous post.
    All this fun can be done with the battery: NI-MH, NI-CD.
    Aku LI-jon, you have to be careful with them, they can explode and get burned when they are unloaded (you need to control the voltage).
    Look in the net, there are a lot of videos, there are people burned.
    So if you don't know it, leave it alone, Christmas is coming slowly.
    Regards.
    krzysiek_krm
    Level 40  
    Help: 716
    Rate: 599
    Regards.
    Let's not exaggerate again, it's not some devilish technology.
    A minimum of caution plus an efficient safety system will suffice.
    szkieletor11111
    Help: 63
    Rate: 149
    I'm not saying it's different.
    However, it can be dangerous.
    The results of various games are on the net, it is worth to watch this way for precaution.
  • #11 16842142
    Brentlok
    Thanks for any help closing the topic ;)
The discussion centers on the appropriate charging current for four lithium-ion laptop batteries connected in series, yielding a total voltage of approximately 14.8V. It is advised to charge at a current lower than the maximum capacity of 2.2A (1C), with recommendations ranging from 1.8A to 2A for longevity. A safer charging current of 0.1C is also suggested, with a charging voltage of around 15V. A formula for calculating charging time is provided: T = 1.4 x C / I, where T is the charging time in hours, C is the battery capacity in mAh, and I is the charging current in mA. Caution is emphasized regarding lithium-ion batteries due to their potential hazards if improperly charged, and the use of specialized chargers is recommended.
