How to Design a 29.4V 4A Charger Circuit for Lithium Ion Battery Packs?
285 7
  • #1 21679931
    Ashish kumar Agrawal
  • #2 21679932
    Rick Curl
  • #3 21679933
    David Ashton
  • 29.4 V chargers from mobility chair battery packs
    #4 21679934
    Richard Gabric
  • Clarifying schematic versus block-level charger design
    #5 21679935
    Justin Spencer Mamaradlo
  • #6 21679936
  • Recommend TI BQ24630 as charger IC
    #7 21679937
    Rick Curl
  • #8 21679938
The discussion focuses on designing a 29.4V 4A charger circuit for lithium-ion battery packs, specifically for a 7-cell series configuration (7 cells × 4.2V = 29.4V) commonly used in applications such as e-bicycles and DC motor-driven devices like powered chairs. Key design considerations include the battery capacity (e.g., 2600mAh per cell), input voltage, load conditions during charging, and efficiency factors such as parasitic elements. For practical design, selecting an appropriate battery management IC is critical. A recommended approach is to use integrated PMIC battery charger ICs suitable for 1 to 7 series cells, with Texas Instruments’ BQ24630 highlighted as a viable candidate. The design can be approached at either schematic or block level, with options including DC-DC converter ICs combined with external components and possibly delta-sigma converters for charge monitoring. Off-the-shelf solutions exist, but custom design requires careful component selection and theoretical analysis.
