[Solved] Ford V Series Radio Decoding: Calculator Availability & Assistance Requests
btomko 7878 8
  • #1 16839580
    btomko
    Help: 174
    Rate: 404
    Are calculators available for these radios yet? Maybe someone has and will help. Thanks.
  • #2 16840901
    volksjet
    Help: 18
    Rate: 60
    The calculator is available from June, you could buy it and of course there is no free one :)
    Buy a martecha may activation with Ford V series after the serial number cost about 890 PLN unless you need to activate box III of course ...
  • #3 16841062
    adam white
    Car audio specialist
    Help: 197
    Rate: 328
    Radios with a TMS470 processor can be made to run on any code (memory edit) - and Martech is not needed at all. All you need is the I2C programmer and of course know-how.
  • #4 16841873
    LWD11
    Help: 223
    Rate: 486
    There are V calculators from the available database which is constantly updated.
  • #5 16842912
    volksjet
    Help: 18
    Rate: 60
    Only this database is currently loaded in 1.8%
  • #6 16843416
    LWD11
    Help: 223
    Rate: 486
    For the delight of those who manage without it. :)
  • #7 16860846
    LWD11
    Help: 223
    Rate: 486
    Old Ford v 9.6.5 database
    The latest today is probably 11.5.7
  • #8 17924944
    neemo
    Rate: 12
    I found a free online calculator for Ford's V series. Full code base.
    www.docauto.eu
  • #9 17925244
    damiancz
    Moderator of Car Radios
    Help: 475
    Rate: 1409
    Resolved = closed.
The discussion centers around the availability of calculators for decoding Ford V Series radios. A user inquires about the current status of these calculators, seeking assistance. Responses indicate that a paid calculator has been available since June, with costs around 890 PLN for activation. Additionally, it is noted that radios with a TMS470 processor can be modified without Martech, using an I2C programmer. There are also mentions of a continuously updated database for V calculators, with the latest version being 11.5.7. A free online calculator was also found at www.docauto.eu, providing a full code base for Ford's V series radios.
