[Solved] 4500 RDS EON Radio in 2005 Ford Fiesta MK6: Seeking Code After Battery Replacement
duch.. 58191 16
How can I recover the unlock code for a Ford 4500 RDS EON radio after a battery replacement?
There is no universal code for this radio, so you need the unique unlock code from the car papers, a local electronics shop, or the dealership, and you should avoid entering random codes because of the lockout risk [#15874719] If you do not have the code, remove the radio and check the sticker on the side; someone can often help decode it from that label [#15874840][#18228180] The dealership method only works if the radio has not been replaced before [#15874719]
  • #1 15874713
    duch..
    Hello, I need help with the 4500 RDS EON radio in a 2005 Ford fiesta mk6, I bought a new battery and there is a CODE - - - - 1. Is there a general code for this radio model? How to proceed now? Because I do not want to type in order not to block. Please help.
    • 4500 RDS EON Radio in 2005 Ford Fiesta MK6: Seeking Code After Battery Replacement 20160817_145810.jpg (512.26 KB) You must be logged in to download this attachment.
    Pawel wawa
    Help: 1262
    Rate: 4433
    There is no generic code. If you don't have the code written down in the car papers, you have to go to an electronics shop in your area or to the Dealership and ask for the code nicely. The second version will only work if no one has replaced the radio.
  • #3 15874840
    marek1977
    Help: 204
    Rate: 710
    Remove the radio and take a picture of the sticker on the side. Maybe I can help.
  • #4 18227716
    __MarkuS__
    Rate: 14
    Hello, sorry for reviving the topic. Is anyone still helping to solve this code problem? Regards
  • #5 18228180
    dare23
    Level 19  
    Help: 32
    Rate: 242
    Send a sticker from the radio
  • #6 18228883
    __MarkuS__
    Rate: 14
    Already, problem solved. Sorry for turning the guitar around. Best wishes.
  • #7 18231532
    Mirek aokowalczyk
    Rate: 8
    I have a radio in a ford fiesta car I bought but there is no code please help. Radio M081118 [img-0]
  • #8 18243631
    dare23
    Level 19  
    Help: 32
    Rate: 242
    Try code: 4557
  • #9 18510933
    kierass2
    Rate: 19
    I have such a radio and after connecting the battery it will ask for a code.
    No. M674905.
    Can someone tell me the code for my radio?
  • #10 18510965
    MarcinS70R
    Help: 52
    Rate: 290
    No. M674905.
    Try 9468
  • #11 18510970
    kierass2
    Rate: 19
    MarcinS70R wrote:
    No. M674905.
    Try 9468
    Correct. Generated I generated the application from the Google Play store.
    Anyway, thanks Martin.
  • #12 18773530
    Ali36
    Rate: 10
    Hello, does anyone of you have the code for this radio M048953
  • #13 18774255
    bodzio012
    Help: 161
    Rate: 780
    Hit 8358
  • #14 18777940
    Ali36
    Rate: 10
    bodzio012 wrote:
    Hit 8358
    thanks a lot 😀
  • #15 18787877
    tomekl92123
    Rate: 14
    Hello, I also have a request for a radio code M003265. Thanks in advance.
  • #16 18787909
    Jurek220
    Help: 159
    Rate: 256
    6325
    Regards
  • #17 18788038
    tomekl92123
    Rate: 14
    Jurek220 wrote:
    6325
    Regards
    Works. Thanks for the help :D
The discussion revolves around the 4500 RDS EON radio in a 2005 Ford Fiesta MK6, specifically addressing the issue of needing a code after a battery replacement. Users clarify that there is no generic code for this radio model. If the original code is not available, the recommended solutions include visiting an electronics shop or a dealership to retrieve the code, provided the radio has not been replaced. Some users suggest removing the radio to check for a sticker that may contain the code. Others share specific codes for different radio units, indicating that codes can vary by model and serial number.
