Control Portos XT-R Radio Blinds via WiFi: Compatible Drivers & 15-Channel Remotes
sekaczu 16872 9
Can I connect Portos XT-R radio blinds to a Wi‑Fi controller, and what compatible driver should I use?
Yes — if you want Wi‑Fi control of the blinds, connect a Wi‑Fi gate/relay in parallel with the wall switch, and make sure it has at least two outputs for up/down control; if the button wiring is 230 V, use a controller with 230 V outputs or intermediate relays [#16896282] If you want direct compatibility with the radio system, Portos Radio, Aluprof Radio, and Yooda are all the same Dooya system and work with each other [#16897188] In that case, look for controllers that explicitly support the DOOYA roller-shutter system, because not every device will work and some are only fixed-code devices [#16898203] The thread points to Zenpro Smart Control as a compatible smart-home central for this system [#17639200][#17639202]
  • #1 16895884
    sekaczu
    Rate: 9
    I have external blinds with flush-mounted (in the switch box) portos controllers (XT-R) it all supports a standard 15-channel remote control (portos). Is it possible to connect it to some Wifi driver (maybe even some remote control with wifi support such as something exists)?
    Wi-Fi gate outputs in parallel with wall switch
    #2 16896282
    kotbury
    Gantry automation specialist
    Help: 2100
    Rate: 3631
    You can - the Wi-Fi gate outputs are connected in parallel to the wall switch - the gate must have at least 2 outputs (these blinds are controlled by directional buttons - there is no single step by step input, you can also use 2 gates with single outputs).
    Just check (neon indicator) that the control signal on the button is not a 230V case - then you have to use a gate with 220 outputs or use intermediate relays.
    As for the gate - very company solutions (e.g. Hormann or companies from the range of alarm technology) are also very expensive.
    But there are equipment from the border of DIY - e.g. Electrodragon (for gouges) or Sonoff (ready solution with access via a cloud from an external net) for less than PLN 40 a piece.
    If you have a lot of blinds and want to control them independently - then you could consider equipment from a simple smart home circle but you need to analyze the costs - Vera Edge from Hong Kong, Croatian Zipato Zipamini (switchboards for around PLN 500 for the simple version) or Polish Fibaro HCL (ok PLN 1,000 for the simple version). Prices of executive modules are unfortunately large (Z-Wave radio system) - from PLN 140 for the cheapest single-channel.
    If you have the option of releasing cables and you care about internet control - there is still a Polish SterBox (about PLN 500 for a drug).
    Marek J.
    Help: 526
    Rate: 951
    This Portos Radio system as well as Aluprof Radio and Yooda are the same Dooya from the PRC.
    They are compatible with each other. You can buy such a miracle:
    http://sukcesgroup.pl/sklep/pl/yooda/intelige...entrala-sterujaca-do-inteligentnego-domu.html
    ... or look for the cheaper equivalent of Dooya on aliexpress or similar sites ...
  • #4 16897441
    sekaczu
    Rate: 9
    Thanks for the hints. I am more interested in such a switchboard that will handle roller blinds but in the future it will be possible to add more things to it.
    Marek J. so out of curiosity this headquarters would also handle it?
    https://pl.aliexpress.com/item/Wsp-pracuje-Z-...u-Bezprzewodowego-Drzwi/32843709447.html?spm= a2g17.search0103.3.191.sIwYzR & ws_ab_test = searchweb0_0 2Csearchweb201602_5_10152_10065_5000015_10151_10344_10068_10345_10342_10343_51102_10340_10341_5130015_10609_10541_10084_10083_10304_10307_10301_10610_5080015_10312_10059_10313_10314_10534_100031_10604_10603_10103_10605_10594_5060015_10142_10107%%% 2Csearchweb201603_25 2CppcSwitch_3 & algo_expid = c7ad8534-2b04-4e8c-8f45-8fcf0ef20296-25 & algo_pvid = c7ad8534-2b04-4e8c-8f45-8fcf0ef20296 & transAbTest = ae803_5 & rmStoreLevelAB = 0
  • #5 16898203
    Marek J.
    Help: 526
    Rate: 951
    I don't think so .... Only fixed code.
    Look for devices that clearly state that they support the DOOYA roller shutter system.
  • #7 17637463
    sekaczu
    Rate: 9
    The topic has been postponed and I haven't bought anything so far, so I'm waiting for the name to be sent
    lukasz_ziel
    Rate: 25
    Zenpro Smart control
    Instructions attached.
    Unfortunately, the auction is gone :(
    I found such a link on the web
    https://systemy.kasiarolety.pl/pl/p/ALUPROF-Z...-Smart-Control-Centrala-Inteligentny-Dom/1103
    but here the price is already higher.
    • ZenproPoradnikInstalatora.pdf (2 MB) You must be logged in to download this attachment.
    • ZenproZSC1Instruction(1).pdf (485.45 KB) You must be logged in to download this attachment.
  • #10 17639236
    sekaczu
    Rate: 9
    I have to think about this, how I decide and I will buy, I will definitely let you know.
The discussion revolves around the possibility of controlling Portos XT-R external blinds via WiFi using compatible drivers and remotes. Users suggest that WiFi gates can be connected in parallel to the existing wall switches, with recommendations for devices like Sonoff and Electrodragon for DIY solutions. Compatibility with other systems such as Dooya, Aluprof, and Yooda is noted, with suggestions to explore options on platforms like AliExpress. Users inquire about specific smart control units, including Zenpro Smart Control and alternatives, while discussing pricing and functionality. The need for devices that explicitly support the Dooya roller shutter system is emphasized.
