Controlling 230V Window Blinds with Smartphone: Central Button, Devices & Setup Advice
jacek1987-1987 14073 7
  • #1 16930177
    jacek1987-1987
    Rate: 15
    I would like to control window blinds wired to 230V using a smartphone. In the installation there will be buttons near the windows and a central button for all blinds, however, I still want to be able to control using a smartphone and I am looking for information on how to do what additional devices I will need to do it?
  • #3 16930302
    jacek1987-1987
    Rate: 15
    This solution will allow me to control the blinds when I am in the building and in the range of the bluetooth operation, and how would I like to close the blinds while being behind the house?
  • #4 16930523
    kotbury
    Gantry automation specialist
    Help: 2103
    Rate: 3638
    Be interested in Sonoff WiFi gateways (chinol but offers an unbeatable price / performance ratio).
    Or much more expensive you can go in a simple smart home and kits on the Z-Wave: Fibaro, Vera, Zipato etc.
  • #5 16932405
    jacek1987-1987
    Rate: 15
    And what do you think about the use of VERSO control panel for such control?
  • Versa panel is too expensive for blinds control
    #6 16932742
    kotbury
    Help: 2103
    Rate: 3638
    I think Versa? Well, it is even more expensive than home automation control panels. Take into account the fact that the control center alone for over PLN 1000 is a goop. A WiFi module, a keypad, a housing, a power supply, a radio remote control, or radio executive systems are another good few hundred zlotys. Secondly - the logic of inputs and outputs is adapted to the tasks of protection and using them as a remote control will pose some problems (here specialists from the above-mentioned alalers could speak).
  • #7 16935002
    jacek1987-1987
    Rate: 15
    So generally you do not recommend controlling anything using the control panel? And if I minimally wanted to do so that arming the alarm will close all the shutters at the same time, do you allow the use of this control panel?
  • #8 16936731
    Marek J.
    Help: 526
    Rate: 951
    Maybe you could give what type of engines will be used at the beginning?
    I'm not just referring to the company / brand but also will it be typical drives with mechanical limiters, maybe with obstacle detection and electronic limit switches, maybe only with an overload device, or maybe with a built-in radio receiver? This will allow us to specify the answer. Some of them can be combined in parallel, others categorically not, yet another is enough to make them run in a given direction and work only in step-by-step mode ...
The discussion revolves around controlling 230V window blinds via smartphone, with a focus on integrating a central button and additional devices. Users express interest in solutions like Sonoff WiFi gateways for cost-effective smart home integration, while also considering more advanced systems like Z-Wave products from Fibaro, Vera, and Zipato. The VERSO control panel is mentioned, but concerns about its high cost and suitability for remote control applications arise. The importance of selecting compatible motor types for the blinds is emphasized, including options with mechanical limiters, obstacle detection, and built-in radio receivers, which affect the overall setup and functionality.
