[Solved] Cheapest Dog GPS Locator: No Subscription, 1-Day Battery, Child Smartwatch Option (PLN 70)
deka87 16026 12
What is the cheapest working way to locate a dog by GPS without a subscription if about one day of battery life is enough?
A cheap GPS dog locator is usually not the children’s smartwatch route, because even that option still requires an active SIM card, so it is not truly free of ongoing costs [#16941251] The more practical low-cost option discussed was a small Chinese GSM/GPS pet tracker bought directly from AliExpress instead of a Polish reseller, since many local products are just rebranded imports [#16941757] One user specifically chose the TKSTAR TK909 mini pet GPS tracker and later reported that it works as it should [#16941757][#17289857] If you want waterproofing, note that the IP68 versions were mentioned as having lower battery capacity, which matters if you need longer standby time [#16941757]
  • #1 16941029
    deka87
    Rate: 37
    I am looking for the cheapest but well-functioning way to locate a dog via GPS.
    The locator must be free, i.e. without any subscriptions, etc. (excluding data and text charges).
    The battery does not have to last long, approx. 1 day is enough.
    I was thinking about a smartwatch for children with a GPS location, on Allegro with a shipment for just PLN 70 you can buy something like this, e.g. http://allegro.pl/bc2-smartwatch-gps-q50-locationator-dziecka-telefon-i6778928328. html? fromVariant = 6666092972
  • #2 16941251
    shortping
    Help: 8
    When it comes to the solution with the said smartwatch - it doesn't fully meet your assumption of no subscription fees, you need to keep your SIM card active.
    In general, the solution is not cheap and functional.
    It is enough to disassemble the strap (only carefully, because in this type of devices antennas are most often mounted in the straps), put it in a pocket closed with velcro at the collar and riding ...
    I have a slightly different solution myself - zone collar.
    It works by reminding the dog that he has moved too far away from the guide who has the transmitter - at first vibration, then annoying ultrasound, and at the very end (only if the previous ones did not work) an electric pulse.
    My dog mastered the scheme of action in three days and never goes away more than 100 - 150 meters.
    But this solution is also a different price shelf - 10 years ago it cost over 2,000 PLN ...
  • #3 16941317
    deka87
    Rate: 37
    deka87 wrote:
    without any subscriptions etc. (not including data and text charges)
    However, the zoning collar is too expensive, and if the dog doesn't get it, that it has to come back and run away, I won't trace it.
    With the watch there may be a problem with mounting, so I'm thinking about something smaller, lighter and waterproof, e.g .:
    - http://allegro.pl/show_item.php?item=70243999...8bf5405c1e387864ffa85323220a14fff770040a2acff
    - http://allegro.pl/mini-alarm-gsm-locationator-gps-i6954567724.html#thumb/2
  • #4 16941412
    shortping
    Help: 8
    Of these two, it is probably only a collar - as for the locator, with such an "accurate" description I would rather not trust this device (or maybe the seller?), The more that according to the mentioned description it does not monitor the position in real time ...
    And the collar is probably the most useful by name ;)
    As for my equipment - I have a house in Masuria, on the very edge of the Borecka Forest and sometimes the animals break down the fence, trying to get to what is growing on the property. If I let the dog loose, I had to be able to have some control over it in case I didn't notice the damage (the fence is over a kilometer and a half) - that's why I chose this solution and decided to train my dog.
    The transmitter is small, as a rule, it lies on a sheltered shelf at the corner of the house (I pulled up additional charging power), and if we want to move somewhere further with the dog, I throw it in the saddle at the saddle and ride ...
  • #5 16941757
    deka87
    Rate: 37
    I did a little research and it turns out that most of the locators on our market are Chinese products sold by Polish distributors, of course with the appropriate margin, so I think I'll decide on this one: https://pl.aliexpress.com/item/2017-New- TKSTAR-mINI-Pet-GPS-Tracker-necklace-GSM-GPRS-TK909-Real-Time-Tracking-Long-STANDBY / 32793332386.html? spm = & a2g17.search0104.3.306.wlB17j ws_ab_test = searchweb0_0, searchweb201602_5_10152_10151_10065_10344_10068_10342_10343_10059_10340_10314_10341_10534_100031_10084_10604_10083_10103_10304_10307_10301_10142, searchweb201603_32, ppcSwitch_5 & algo_expid = 2d745e0e-b2d8-4938-9eec-57b6a23133b8-41 & algo_pvid = 2d745e0e-b2d8-4938-9eec-57b6a23133b8 & transAbTest = ae803_5 & priceBeautifyAB = 0
    There are even locators with IP68, but unfortunately they have batteries with a much lower capacity, and this is quite important if the search was to last longer, besides, our dog does not like to go into the water so such a degree of protection is not needed.
  • #6 17099704
    trombson
    Rate: 21
    And maybe someone had this one - https://sklep.ysznenczesina.pl/locsatory-obroze-gps-dla-zwierzat?
    In general - what are the differences between these solutions?
    For now, I'm just recognizing the topic, but I would like to buy something quickly.
    I have invested a little in doggy, and we have some massacre with these thefts of animals in the estate.
  • #7 17099814
    deka87
    Rate: 37
    I have no idea what the differences are, you need to do an investigation and find out what this locator is doing and compare the data on the manufacturer's website with others.
    The locator is a rather poor protection against dog theft - the thief will rather take off the locator as soon as possible, unless he is not very familiar with the technology and will not be distracted that it is the locator.
  • #8 17104175
    trombson
    Rate: 21
    That's right - so the question is, what will be effective?
    On the logic - a dog dies from a public place, so the guy can not just immediately break the collar and run, because someone will notice it.
    And you get the alert right away ...
  • #9 17108068
    franek455
    Trombson - we have this collar.
    Our friends found their dog three weeks ago thanks to the locator - the guy stole it from the store.
    The dog was 3 blocks away. It seems to me that animals steal mainly random people and on average think about breaking the collar.
    But what do I know. We bought a dog collar just in case.
  • #10 17113325
    trombson
    Rate: 21
    This is not a big deal, so yesterday I ordered exactly this Locon locator.
    If it doesn't work, I will sell it or return it sooner.
    I don't know how it looks from the inside, but it seems to me that "professional" thieves do not deal with dogs from under the shops.
    It's more about protecting yourself against typical idiots.
  • #11 17116519
    franek455
    The risk of dog theft is not great, it should be more a way to reduce dog loss. Rather, he rarely stays alone anywhere. If I go for a walk, I don't go to the store. You also need to think sensibly - the collar will not save you from everything.
  • #12 17122031
    trombson
    Rate: 21
    I agree with what you write. We already have a collar at our place, the location works the most - I can see, for example, what route the daughter is walking on.
    Let's never use it to look for him, because we don't care about such attractions.
    Let him just wear it.
  • #13 17289857
    deka87
    Rate: 37
    I bought TK909 from AliExpress, it works as it should.
✨ The discussion revolves around finding an affordable GPS locator for dogs without subscription fees, with a battery life of approximately one day. The initial suggestion was a child smartwatch available for PLN 70, but concerns were raised about the necessity of an active SIM card and the overall functionality of such devices. Alternatives like smaller, waterproof GPS locators and zone collars were considered, with some users sharing their experiences with various products. The TKSTAR mini GPS tracker was mentioned as a viable option, and users expressed the importance of understanding the limitations of these devices, particularly regarding theft prevention. Overall, the conversation highlighted the need for effective tracking solutions while balancing cost and functionality.
TL;DR: A trained “zone collar” kept one dog within 100–150 meters; “never goes away more than 100–150 meters.” It’s a proven low-tech complement to cheap GSM GPS tags. [Elektroda, shortping, post #16941251] Why it matters:** You want the cheapest way to find or deter a roaming dog without ongoing subscription hoops; this FAQ shows what actually worked for real owners and what to avoid.
Does a kid’s GPS smartwatch meet the “no subscription” goal?
Not fully. It still requires an active SIM for GSM data and texts, so there are ongoing charges, even if small. [Elektroda, shortping, post #16941251]
What’s the cheapest workable tracker option people actually tried?
A kid’s GPS smartwatch around PLN 70 was considered, but mounting and durability are concerns. Users also reported success with TKSTAR TK909 as a pet-dedicated unit. [Elektroda, deka87, post #16941029]
How do I attach a small GPS to a collar securely?
Remove the original strap carefully. Antennas may be in the strap. Place the device in a Velcro-closed pocket sewn to the collar to keep it oriented and secure. [Elektroda, shortping, post #16941251]
Are GPS collars effective against theft?
A thief can remove a locator quickly. One user cautioned trackers are weak as anti-theft; use them mainly to recover a wandering dog. [Elektroda, deka87, post #17099814]
But do trackers ever help in theft cases?
Yes. One report describes finding a stolen dog three blocks away thanks to the locator. “Animals steal mainly random people,” they added. [Elektroda, franek455, post #17108068]
What is a zone collar, and does it work?
A zone collar links a dog unit to a handler transmitter. It warns by vibration, then ultrasound, then a pulse if the dog goes too far. One dog learned in three days and stayed within 100–150 m. [Elektroda, shortping, post #16941251]
Quick how-to: train with a zone collar
  1. Start at short range with the transmitter and let the dog hit the vibration boundary.
  2. Reward return; repeat until the dog responds consistently to the first cue.
  3. Gradually extend distance; avoid relying on the pulse stage. [Elektroda, shortping, post #16941251]
What ongoing costs should I expect with “no-subscription” trackers?
Plan for SIM activation plus small data/SMS usage. The device must remain reachable on GSM, even if the platform itself has no fee. [Elektroda, shortping, post #16941251]
Is IP68 waterproofing worth it for dogs?
If your dog avoids water, IP68 may be unnecessary. One buyer chose higher battery capacity over IP68 because search time mattered more. [Elektroda, deka87, post #16941757]
Which budget pet tracker model did owners confirm works?
TKSTAR TK909. A user purchased it on AliExpress and reported it “works as it should.” [Elektroda, deka87, post #17289857]
Can I review my dog’s walking route later?
Yes. A user noted seeing the exact route their daughter walked with the dog, confirming usable historical traces. [Elektroda, trombson, post #17122031]
What’s a realistic battery expectation for ultra-cheap setups?
Target about one day when actively tracking. The original requirement set 1-day life as acceptable for daily charging routines. [Elektroda, deka87, post #16941029]
Are all low-cost “GPS locators” real-time?
No. Be wary of vague listings. One discussed unit did not appear to provide true real-time monitoring per its description. [Elektroda, shortping, post #16941412]
How far can a zone collar cover around home or land?
A handler reported managing a property with over 1.5 km of fencing and using a transmitter placed at a sheltered spot to keep coverage consistent. [Elektroda, shortping, post #16941412]
What should I check when comparing store-brand locators?
Investigate manufacturer specs and verify features against other models. Don’t buy on branding alone; confirm functions first. [Elektroda, deka87, post #17099814]
Will a collar solve every safety scenario?
No device replaces judgment. “The collar will not save you from everything,” so plan walks and supervision accordingly. [Elektroda, franek455, post #17116519]
